Re: TrailMaster Lift
2dr or 4dr? Let's see I have a bone stock 89 S-15 ext cab with stock 15x7" factory rim and no rubbing with 31x10.50 BFG AT's. Your problem is like everyone else's, I'm sure. You have an 8" rim center set and the stock rim is either 6" or 5.5" rear. That means you moved the tire out at least 3" and it rubs. You will have to probably go up at least 3" to stop it from rubbing if that's the case. Go out, you need lift, go bigger you need lift. Go to S-10 4x4 and they have a tire/wheel chart that's not way off. Tom
Tom "Deep Sea Diver" Brantley
