Body vs. Suspension Lifts? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-25-2000, 02:21 AM
im askin way too many questions but i dont care, im 19 and ive got no experience, u guys are the easiest and most knowledgable source... My situation is with my ZR2, i want to lift it, but im debating whether i should just do a 3" body lift and throw 33s on it and be done, or if i should go with the 6" Superlift Suspension Kit... i know body lifts can be a bitch, but i also know that suspension lifts can be a problem for you ball and CV joints, etc.... i think this is a good question though, to compare the trade-offs between body and suspension lifts, though i know people do both...
which do u guys think causes the least wear and tear, and/or future problems for your truck... my guess is definitely the body lift bc its not altering much, but id like to see your opinions.. thanks
Dan
'95 ZR2 brilliant blue baby!
post #2 of (permalink) Old 12-25-2000, 09:36 AM
Re: Body vs. Suspension Lifts?
I'll do it this way...
Body Lift
Pros: Cheap! Lifts the body to accept larger tires. Makes easier to clean mud off the frame.
Cons: Only lifts the body. Does NOT provide any form of clearance by frame or suspension. Body mounts, if not properly done, can be bent up under heavy use (you can gussett the stock body mount area to fit the new lift). You must disconnect all cables and wires that attach to both the frame AND the body if your lift is higher than the cable/wire length. Possible shifter problems; might need new or adjusted linkage. Leaves interesting gap between frame and body.
Suspension Lift
Pros: Lifts the frame. "True" lift. Gives you a longer A-arm (either top or bottom). Allows you to get longer, better shocks. Chicks dig 'em! [img]/wwwthreads_images/icons/smile.gif[/img]
Cons: Drops the front differential to maintain the correct angles. Doesn't provide suitable ground clearance from that front diff. "Can" wear out CV's and U-joints if not properly installed and aligned. Expensive compared to body lifts! Some shops have problems aligning trucks with lifts. Might require the use of blocks in rear (I don't recommend blocks) or new springs.
That's all I can think of. I'm too busy thinking of what Santa brought me!!!
http://members.xoom.com/desertride/index.htm
J.R. is offline
post #3 of (permalink) Old 12-27-2000, 04:19 PM
Heres the thing...Do want cool big tires, or do you go off road and need extra suspencion travel... Odds are if you just want cool tires i'd go with the body lift, if you want a really cool useable truck off road then go with the suspencion lift.
Tim
88 blazer
Like A Rock
post #4 of (permalink) Old 12-27-2000, 06:16 PM
HOw u Doin.......you may pay more for a suspension lift, but trust me, its well worth it. A body lift will be nothin but trouble in 5 years. My buddy cracked his chassis because of a body lift. You get absolutely no more travel than you had before, and besides poorer performance it looks tacky as hell having your whole frame visible from the outside. Hope this helps.
-Steve
