broken rear latch - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-21-2000, 01:13 AM
broken rear latch
my rear door latch is busted. My 3.4 is partially in. I forget if pushing the rear window button on the 86 jimmy pops the window? the battery and accessories are not hooked up yet so i can't pop the button. Is the another way i can open the rear gate? thanks
jeff
jeff
86 4x4 2.8/3.4 jimmy
84 fiero 2m4
parked 86 2m6
post #2 of (permalink) Old 12-21-2000, 12:26 PM
Re: broken rear latch
other than using a key, or hitting the button, your kinda screwed. You could try wiring the switch to battery (direct). Or depending on the style of the latch, you can unbolt it from the window, and remove the handle. That should let you open the glass. But the "U" hook will still be locked in the door so you won't be able lower the tailgate.
post #3 of (permalink) Old 12-21-2000, 01:45 PM
You can open your tailgate but first you do have to open the window. Then all it takes is a large screwdriver to turn the lock mechanism on the inside. If you can't get the window open use a medium size flat tip to push the latch back, starting from the outside and go up. If all that fails you can use two small screwdrivers one on each side of the tailgate from the inside to pry the latches. None of this will damage your truck except prying the window open. Good luck if you need any more help let me know.
post #4 of (permalink) Old 12-21-2000, 03:53 PM
All you have to do is just hook up the + and - batery terminals to the battery and push the button inside to pop the latch!!
1991 S10 Blazer Tahoe 4x4. Edelbrook Headers, Holley 670cfm TBI, K/N filter charger, 30-9.5-15 tires, rebuild worked tranny
