bushwacker flares - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-22-2000, 12:25 PM
bushwacker flares
i was wanting to know if anybody has installed a set of the bushwacker fender flares on there s-10 how hard was it and was there any tricks to it also my 89 s-10 blazer makes a loud pop noise when i make a sharp turn left or right and the sound seems to be coming from the passanger side of the vechile any ideas thanks
Suck'n Gas & Haul'n Ass
~fight to keep public land open~
post #2 of (permalink) Old 11-22-2000, 01:31 PM
Re: bushwacker flares
The flares I have are very simple they just sit up against the wheel openings and you can put screws through them, my 89 had factory chrome trim around it so i just used the pre drilled holes that were there already, clunking could be a ball joint, could be a cv joint or in my case I had this problem once and the bolt were you can adjust the upper A-arm was really lose, make sure the front end is tight and check every thing closely, you'll find your clunk.
post #3 of (permalink) Old 11-22-2000, 02:15 PM
yeah those type of flares are pretty simple i have a set of gm black plastic ones on there but i wanted the cut out flares the ones that you have to cut out the wheel well and for the popping noise i changed the ball joints and it still does it and i also changed the cv joints ont that side but it does need a front end alignment really bad its so bad you can see the tire actully tilted out so i might do that alignment and see if changes
post #4 of (permalink) Old 11-22-2000, 03:17 PM
Don't forget to look at your bushings up front, they get dry rotted and start to have play in them
post #5 of (permalink) Old 11-22-2000, 09:32 PM
also don't forget to check the torsion bar mounts. I chased that popping noise before too. And it was no fun finding out that all I needed was 2 $24 mounts after buying all new ball joints and cv joints.
To check them simply push up on the crossmember that holds the torsion bars if it moves then they need to be replaced.
