Steering colum--tilt - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-13-2000, 06:17 PM Thread Starter
I am a new user and I need some help with my 1989 S-10 Blazer 4x4. I received the vehicle about 6 months ago. The tilt is way to loose. I was taking it apart and I cannot get to the bolt or whatever it is that needs to be tightened. I have the column taken apart down to the tilt. I cannot get the sleeve off to get to the bolt or whatever it is. Can anyone help me with this problem?
On one of the earlier posts I had seen where someone had to replace the windshield wiper switch. Where can I get one pretty cheap?
"Redneck" on the internet
TexasRedneck is offline
post #2 of (permalink) Old 11-13-2000, 08:15 PM
Re: Steering colum--tilt
I'm having the same problem in my 91 S10 Blazer. It just started to get worse in my column. Hopefully I can figure this out soon!!!
post #3 of (permalink) Old 11-13-2000, 11:14 PM
I got this over at coloradoK5. I don't know if the s10's are different, I'm too lazy find out.
I should give credit to who gave this info, but [img]/wwwthreads_images/icons/blush.gif[/img] I forgot who it was.
Here is the infamous “GM tilt column loose problem” fix:
Disconnect the Battery, Tilt the column to the full UP position, Pull the wheel
Remove the locking plate, the large spring & the bearing cover (This comes off fine, but is a pain in the butt to get back on so I made a tool to put it back on)
Disconnect the connectors for the turn signal switch, cruise and the "smart" switch
Remove three screws that hold down the turn signal switch
Gently pull the switch up and pull out of the housing folding down and hang by harness
Remove the Ign Key buzzer switch and retainer clip
There is either a screw on the right side holding in the IGN KEY LOCK or a slot in which you push a tab.
Remove the screw or push the tab and remove the Ign Lock Cylinder.
Most of us have been this far before into the tear-down.
Next there are three or four torx head screws that hold the housing onto the tilt bowl, remove them.
Return the turn signal switch back into the housing, do not put the screws back. This step is to give you some play in the wiring
Gently pull up on the housing up and over the steering shaft. Tilting the shaft down will help but it puts the upper ball bearings in danger of popping out. The small cover for the tilt handle, the plastic push piece will all fall out
There will now be a black bowl exposed. It has the bearings for the short shaft. The Hi Beam actuator rod will be coming through on the left side. There will also be a small rod through the top parallel with the floor. It is the sector shaft for the IGN Switch and has a small gear on the left.
THIS IS IMPORTANT!! THIS IS THE PART THAT IS SPRUNG LOADED!!
At the bottom is a small, about the size of a quarter, round silver plug with a square cutout in the center. This is the spring retainer. by tilting the column up most of the load has been removed from the spring. Take a #3 Phillips screw driver, put into the square hole. The object is not to go through this hole but to engage it. Push the plug down/in about 1/8 inch and turn counter-clockwise. There are two ears 180 degrees apart that retain the plug. REMEMBER IT IS SPRING LOADED!! Ease up until there is no load and pull out.
The next step requires a small puller. I used small screws and vise-grips on one and a small crow bar on the other one !! They are in there pretty tight too !!
There are two pins 180 degrees apart on the sides of the bowl. These are the tilt pivot pins and they need to be removed. Kent-Moore makes the special puller but I have seen other folks put a small screw in the hole and pull them out with Vise-grips. If the screws break you are hosed! The pins are harden and can't be drilled out if it gets screwed up.
Once the pins are out put the tilt lever back in. Pull like you want to tilt the column. This releases the pawls from the retainer grooves.
While holding them released, gently pull the bowl up towards you. The ball bearings are in danger of popping out again as they are disengaged from the races.
You will notice that the upper shaft is connected to intermediate shaft by a white plastic ball socket. DO NOT BEND THIS TO 90 DEGREES OR IT WILL BECOME DISENGAGED!!
Slide this to one side and two of four torx head screws will be exposed. I use a ¼” drive ¼” socket on a flex universal to gain access. This eliminates the danger of bending the tilt ball too much.
If it's real loose tighten one from each side diagonally, That way the mechanism will seat and not bind. I recommend that you put locktite on them !!
Going back together is just doing it in reverse with some extra steps.
Reposition the tilt bowl on the shaft, pull back on the lever and slide on. Make sure the pawls engage the retaining grooves. The rods down to both the starter switch and the headlamp dimmer need to be lined up.
Replace the tilt spring by depressing with a screw driver and turning
To time the start switch the small snap ring retaining the sector gear, white or black plastic, and gear needs to be removed
These will not be replaced until after the pivot pins are reset.
Install these pins with a gasket hammer, SMALL! You may need to jiggle the bowl by actuating the lever disengaging the pawls
Now time the ign rod rack with the gear and actuate a few times to make sure the Large cutout in the gear for the ACCESSORY position is timed. The rod has a tit that has to go into the racks crescent shaped area. This crescent shaped area allows the rod to be actauted from any tilt position when the key has been turned.
Slide the turn signal housing down over the bowl, aligning the small tilt lever cover and headlight dimmer actuator. Small daps of grease will help hold this in position while trying to put it all together
The rest is put together as taken apart.
The Ign lock cyl goes in before the buzzer switch. The small tab on the lock cyl that actuates this switch needs to be held up in the close position. The IGN key needs to be out of the cyl for this to happen. Small dabs of grease will hold this up during assembly
Another tip:
Loosen the two nuts, maybe three that hold the column up to the dash frame. They are either 17mm or 15mm bolt heads. This will give you a little more play in the wiring.
Hit? Them tires rub. Rubbin's off roadin.
My web page
http://www.bernie.4t.com
post #4 of (permalink) Old 11-13-2000, 11:32 PM
piaa_nissan's Avatar
88Blazer, I love your tagline!! Know what ya mean!
http://www.skyboom.com/Robison
piaa_nissan is offline
post #5 of (permalink) Old 11-14-2000, 12:48 PM
Usually once you get the column cover off you can see a couple of the reverse torx bolts,you can tighten a couple of them which will tighten up the column without have to tear the whole thing apart.
1991 blazer 4 dr 4.3 headers,flowmaster,k&n,31x10.5x15 bfg allterrains
post #6 of (permalink) Old 11-14-2000, 04:21 PM Thread Starter
Thanks for all of the help and comments. I will try it and tell ya'll how it works outs.
post #7 of (permalink) Old 11-16-2000, 11:12 PM Thread Starter
There were two screws instead of four like on the K5. They were burried deep inside of the column. The sleeve didn't need to be taken off, but I had to look real hard to find the screws.
Thanks for all of the help.
post #8 of (permalink) Old 11-22-2000, 03:14 PM
I just fixed my loose steering tilt column!! There was 4 reverse torx srews that need to be tighten and seal with locktite.
