31's on stock 88 blazer? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-29-2000, 02:17 PM Thread Starter
31\'s on stock 88 blazer?
A buddy of mine is going to replace his ugly street tires, and get my old BFG A/T, but would 31" tires fit on a stock 1988 Chevy Blazer? if not, what is the biggest tire he can put under there with out rubbing? Thanks
AARON
Drive it like you stole it!
AARONR is offline
post #2 of (permalink) Old 10-29-2000, 03:47 PM
Re: 31\'s on stock 88 blazer?
what ive understood is the 30x9.5 is about as big as you can go...im going cheep by turning the torsion bars and adding add a leaf for my 31"s
post #3 of (permalink) Old 10-29-2000, 07:38 PM Thread Starter
How would i go about cranking the T-bars? is there a write up some where? and it's the s-10 style, 4x4. I forgot to mention that. Thanks
AARON
AARONR is offline
post #4 of (permalink) Old 10-29-2000, 08:26 PM
Here is a link to t-bar cranking. http://s10-4x4.com/EasyLift/
Using stock rims, the 31's will fit with either a t-bar lift or trimming the back part of the front inner fender.
Hit? Them tires rub. Rubbin's off roadin.
My web page
http://www.personal.psu.edu/bjh182
post #5 of (permalink) Old 10-31-2000, 09:45 AM
What part of the fender do you cut? If I cut this, I can put 31x10.5s on a stock truck? What do you cut it with and what do you fill the hole with?
post #6 of (permalink) Old 11-01-2000, 06:40 PM
No offense meant! but those shackles look a little scary to me, I would be worried about side to side leaning ( // ) or ( \\ )without a brace in between them the way the factory shackle is.
Scooby Dooby Doo !!!
Scoobydoo is offline
post #7 of (permalink) Old 11-01-2000, 07:57 PM
I run 30x9.50's and they rub at full lock. Not every S-10 is the same. I even put in add-a-leaf, and I DID crankup my T-bars a little bit , but not all the way. I don't like longer shackles either. Maybe its just preference but I'd rather go with a little stiffer ride and the add-a-leaf's......... Just my two cents.
post #8 of (permalink) Old 11-02-2000, 01:29 AM
btn
I put 31s on my 90 S10 pu. They didn't rub at all in the back, but in front they did slighty rub the frame and the back of the fenderwell at half-lock going over bumps. That was with no modifications at all to the suspension. The rubbing wasn't enough to be that big of a deal though. I went for years with them.
btn is offline
post #9 of (permalink) Old 11-27-2000, 02:18 PM
I put my upper balljoint's on the bottom of the a-arm and then cranked the bars. On the back I just made some shackles and put an add-a-leaf in. Done deal and you still can use the stock length shocks.
Ben
