HELP!! 4.3 Oil problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-09-2000, 10:32 PM
Help! tonight, I was running an easy trail when the oil pressure hit 0. I cut off the engine immediately, then waited a min, and then restarted. It was fine for a few, then it did it again. I repeated this process 3 times on the way back home. On the trail and on the road (once). I just had my oil changed (3 days ago) and notice the first day that the pressure was slightly lower than normal (3-5 psi). It was pretty scary. Any suggestions on what went wrong? I am thinking it could be the oil pressure sender wires, but I am not sure. I checked the level of oil, and it seemed fine, but then again, I was in bad lighting. Any help would be extremely appreciated. Thanks!! Keep on 'roadin!!
post #2 of (permalink) Old 10-09-2000, 11:48 PM
Re: HELP!! 4.3 Oil problem
Sounds like the sending unit to me. check the wire over really well for cuts or wear marks.. Mine got wore threw this summer during a froading trip and it was grounding out on the frame.
Good Luck
Nick
[email protected]
83' s10 extended cab 4x4 supercharged 2.8l v6
post #3 of (permalink) Old 10-09-2000, 11:52 PM
Drew K1500
These engines have had notorious problems with their oil pressure gauges.
post #4 of (permalink) Old 10-10-2000, 12:39 AM
Thanks for the help guys....I'll let you know what happens.
check out my page... http://home.att.net/~fullreversal
post #5 of (permalink) Old 11-06-2000, 10:41 AM
Here is the scoop on the sending unit guys. As I finally got the connector off of the sending unit, I found oil in the connector. not just a little, but a lot...the oil punched through the sending unit and into the connector! I have never seen anything like it! thanks for all of the help on this!
fullreversal
Mud, Snow, Rain??
All-Terrain!!
