I need help with my wipermotor - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-20-2000, 10:48 PM
My wiper motor quit working all of a sudden. I checked the fuse its good. What I did find is that the housing is "energized" if I ground the housing the motor works. I dont want to permantly ground the housing because I am afraid it might damage someting. What could be causing this? Can I ground the housing without burning something up? A new motor is $50 and I havnt had a chance to check the junk yards. The weird thing is that it works if I ground the housing. Can someone help me on this one? By the way its not a delay model.
92 S-10 Blazer 4x4 Vortec 4.3
85 S-15 Pickup 4x4 2.5 iron duke(mud bog qual'ed)
post #2 of (permalink) Old 09-21-2000, 06:42 AM
Re: I need help with my wipermotor
It sounds like its the switch. Have you had the "phantom wipers" previously
discussed here? If so, then I sugggest replacing the switch. I have a similar problem and replaced the motor with a good used one and it still acts the same. I haven't replaced the switch though. This seems to be a common problem on these trucks inter. wipers or not.
A.S.
1989 S10 4x4 355
1989 S10 Blazer 4x4 4.3
post #3 of (permalink) Old 09-21-2000, 09:50 AM
I wonder if I lost the ground. Today I'm going to try and ground the "ground" wire and see if that works. How could I check and see if it is the switch? What is weird is ... if I run a jumper from the firewall to the housing of the wiper motor it works. If I check the ground wire for continuity with it unplugged its open. When I plug in the wires the ground is hot. This is telling me that the motor is either shorted to ground or the power is back feeding because of a lack of ground. If the motor was shorted internaly I would think that it would pop the fuse when I grounded the housing.
post #4 of (permalink) Old 09-24-2000, 12:09 AM
Can anyone help me out with this problem?
post #5 of (permalink) Old 09-24-2000, 02:55 PM
Your wiper housing is suppose to be grounded. I checked both of my trucks and they were both grounded, and the wiring schematics show that also.
Hope this helps.
David G.
'91 S15 Jimmy 5.7L 4X4
Blazernut is offline
post #6 of (permalink) Old 09-26-2000, 10:24 AM
Well....I went to the junk yard and the guy let me try a used motor in the lot and it worked the same as mine. So what I did was just run a jummper wire from the fire wall to the housing and so far it has been working great with no other problems.
post #7 of (permalink) Old 09-26-2000, 10:35 AM
Soooo this can be attributed to "bad ground"?
http://members.xoom.com/desertride/index.htm
J.R. is offline
post #8 of (permalink) Old 09-27-2000, 08:08 AM
not nessasaraly. The wiring harness "ground" when jumped to ground shorts and makes the fuse pop. But if I "ground" the housing to the firewall it works. This would indicate to me that some place I am getting a back feed of power back through the ground, which would normally indicate a bad motor. However a known good motor acts the same way. Some others have sugested a bad switch but I havnt torn the collum apart to check it yet.
