transmission kicking - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-23-2006, 05:35 PM Thread Starter
Hi there. I have a '94 "chevota" with a 700Ri tranny in it. The tranny went out last October and it had to be rebuilt (in the middle of a 2month road trip, no less). It had been kicking before the rebuild, but you could manually shift it a bit to ease the kick. After the rebuild, it was good for like a day and then started kicking again! It still kicks, not nearly as bad and only in between 1st and 2nd, but it really gets my goat since we paid a lot of money to get it fixed and it's not perfect. Now, to top it all off, it is apparently leaking tranny fluid from somewhere. Has anyone had this experience? Does anyone have some advice? The work is supposedly under warranty but we've had issues with getting the mechanic to honor this warranty before on radiator work that was done at the same time as the tranny. Long, annoying story, but yeah.
gnut is offline
post #2 of (permalink) Old 03-27-2006, 10:55 PM
Re: transmission kicking
Um, kicking.
Does it always kick, or just when your on it hard? And was it a strait rebuild, or did they mess around with anything when they were in there?
MouseMotor is offline
post #3 of (permalink) Old 03-28-2006, 02:41 PM Thread Starter
it pretty much always kicks. it actually kicks a bit less when you gas it right before it shifts. and there seems to be some correlation between environmental temp and severity of kicking. i was thinking about just changing the transmission filter. think this will help? it's also leaking tranny fluid from somewhere, so we just stay extra vigilant on fluid levels.
gnut is offline
post #4 of (permalink) Old 03-28-2006, 10:15 PM
changing the filter is a first step.
next, check the linkage. both for the kick down cable (if you have one) and to make sure that your shift thingy on the side of the trans is popping into each gear properly. i don't know how your shifter is rigged up, but you want to make sure that you are "clicking" totally into each gear. if it is a little off, it will cause it to kick. you are trying to be in 2 gears at the same time basically.
to check, i always disconnect the linkage from the trans. then i have someone shift the truck into each gear on the column how ever you have it rigged up. move the trans thingy into each respective gear that the truck's shifter current position. make sure the linkage slips together without anything being out of line. if it is, your forcing the trans to be in 2 gears at once.
if you have the pan already off doing the fluid swap, you can double check it with your eyes. you'll see the little follower and where it fits into a tooth like thing on a spring inside the trans, just inboard of where the rod goes into the trans.
with that said, all your chevy trans have a little kick. i have had all the major trans at some point, th400, th350, a few 700r4s.
the kick comes from two things. one is the trans are a little worn on some. so, the kick is it grabbing between gears because clearances are a little loose. the other kicks are because a few of the trans were built up. the quicker the trans shifts and grabs between ranges, the more HP it can take without ripping apart the clutches and bands. the kick comes from one clutch or band letting go, and the other grabbing right away. this allows for minimum wear.
if it were too smooth, it would mean that one is starting to grip while the other has not quite let go. this causes excessive wear. mix this with a warmed over small block and your trans will have a short life.
i'd check the linkage first. esp if it was rebuilt. they might have just bolted it back together and not checked.
post #5 of (permalink) Old 03-29-2006, 02:37 PM Thread Starter
thanks a bunch! will do the filter change and then move on from there. one problem (possibly a really stupid question) but how do i check the linkage on an automatic? i feel that this is a very likely cause since the work that was done seems to be quite shoddy. i mean, it's leaking fluid for goodness sakes! after charging us to "reseal the transfer case!"
gnut is offline
post #6 of (permalink) Old 03-29-2006, 05:55 PM
what i said above is for an auto. i'm not sure what your set up looks like, but the idea is to have the trans in a gear and your gear shifter in the same gear. all the linkage should line up, and just slip in and out. if you have to move stuff, or stuff is just a little off, that means that your trans might be between gears even though your shifter in the truck says you are in "D".
also, check the linkage itself. if it is slopply or loose, again the trans might not be fully in the gear.
post #7 of (permalink) Old 03-30-2006, 11:25 AM Thread Starter
thanks so much! will try all this soon....
gnut is offline
