gas mileage - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-14-2004, 03:21 PM
mxkx250
gas mileage
I have a 2000 ZR2 and have always gotten bad gas mileage, 14.5mpg. I recently started getting worse 11.7. It is an auto with 37,000. I haven't changed any maintenance items yet, plugs, wires. I ahve installed a K&N FIPK and GMAFS when the truck was new. I have heard that the oil type air filters can cause the transmission to slip. I don't feel any slipping.
Does anyone have any ideas?
Thanks
post #2 of (permalink) Old 11-14-2004, 07:53 PM
84S_10Blazer
Re: gas mileage
Try running Sea Foam through your truck. Buy 3 cans then put 1/3 in your PCV valve. Let it sit for awhile, then pour the rest in your fuel. Cleans out the engine extremely well. (Its a cheaper version to our fuel injector cleaning at GM). About 3,000 miles after doing this, do some major maintenence such as oil/filter change, fuel filter change, spark plugs/wires, etc.... As far as the oiled filters, that's news to me. I have not heard aniything like that nor does it make any sense to me.
post #3 of (permalink) Old 11-15-2004, 07:47 AM
mxkx250
Re: gas mileage
Thanks for the idea.
Here is the article I was speaking of.
There was a picture, but I can't get it to post here.
WARNING: All K&N And Other Rechargeable Air Filter users
The following is a memo from GM stating the use of rechargeable air filters may cause transmission shift problems, engine driveability problems & SES Light On problems (throwing codes). It also states these problems will NOT be covered under warranty. Yes, in part of the memo, it states "excessively oiled" filters. But for the most part, it reads any use of this type of filter & these issues won't be covered. I just figured some of you might want to know so you can throw a paper filter in if you take your car in for a problem.
SERVICE - ALL BUICK, CADILLAC, CHEVROLET, GMC TRUCK, ISUZU, OLDSMOBILE, PONTIAC AND HUMMER DEALERS
Subject: A/T Shift, Engine Driveability Concerns or SES Light On as a Result of the Installation of an Aftermarket Reusable, Excessively Oiled Air Filter -- 2004 and Prior Cars and Lt Duty Trucks and 2003-2004 HUMMER H2
Message #: VSS20040056
Corporate Bulletin Number 04-07-30-013 will be available in SI on March 18, 2004.
Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES)
Models: 2004 and All Prior Cars and Light Duty Trucks
2003-2004 HUMMER H2
DO THIS
First, Inspect the vehicle for a reusable aftermarket excessively oiled air filter
DON'T DO THIS
DO NOT repair under warranty if concerns result from the use of a reusable aftermarket oiled air filter.
The installation of an aftermarket reusable, oiled air filter may result in:
1. Service Engine Soon (SES) Light On
2. Transmission shift concerns, slipping and damaged clutch(es) or band(s)
3. Engine driveability concerns, poor acceleration from a stop, limited engine RPM range
The oil that is used on these air filter elements may be transferred onto the Mass Air Flow (MAF) sensor causing contamination of the sensor. As a result, the Grams per Second (GPS) signal from the MAF may be low and any or all of the concerns listed above may occur.
When servicing a vehicle with any of these concerns, be sure to check for the presence of an aftermarket reusable, excessively oiled air filter. The MAF, GPS reading should be compared to a like vehicle with a OEM air box and filter under the same driving conditions to verify the concern.
Transmission or engine driveability concerns that are the result of the installation of an aftermarket reusable, excessively oiled air filter are not considered to be warrantable repair items.
Here is a pic of the actual bulletin from GM's internal website.
post #4 of (permalink) Old 11-15-2004, 11:44 AM
84S_10Blazer
Re: gas mileage
Thanks for the SI number. I got on at my dealership and sure enough it was in there. I did not know that, thanks for teaching me a little something [img]images/graemlins/40BEER.gif[/img]
