OUCH! check out these pics - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-19-2003, 04:30 PM
killabeez
well.............................................. ..................................i THOUGHT it was the pinion seal! time to start looking for a new rearend! i doubt im going to find another pussy s-10 rearend WITH 4.10s and a posi so it looks like im going to have to swap my steez into a new housing, correct? im not at all opposed to getting a heavier rear but what would be a bolt in? i have no access to welding/cutting but i can pull some [bleep] from the junkyard! under these conditions, would i be better off doing a swap rather than trying to put my gearset in another housing?
[img]images/graemlins/cussing.gif[/img] [img]images/graemlins/cussing.gif[/img]
post #2 of (permalink) Old 07-19-2003, 06:08 PM
Re: OUCH! check out these pics
Try finding a 12-bolt from an old Camaro if ya want beef. Only thing is, your 4.10s ain't gonna fit. find a 10 bolt from a more current camaro, and you might luck out and get disc brakes.
post #3 of (permalink) Old 07-20-2003, 05:08 PM
killabeez
are the spring perches in the same spot?
post #4 of (permalink) Old 07-24-2003, 12:44 PM
killabeez
i think only some of that lip broke off...can someone help me with this? would that affect the rearend function at all? i can't find any rearends with posi's so i'd really like to keep this one.
post #5 of (permalink) Old 07-24-2003, 05:36 PM
imported_stimpy2
here is an idea to toy with. What about running a new axle (a Toyota 8" and installing an electric locker) This will give you the street preformance of a limited slip and the off road abilities of a locker when you want it with a push of a button. You wouldn't need to install a compressor and air lines or deal with a completely locked rear end. I know it is a little crossbreeding and I am not sure it would line up exactly but I have seen it once but not with the electric lockers this one hade detroit lockers and 4.56 gears.
post #6 of (permalink) Old 07-24-2003, 11:59 PM
killabeez
well theres a huge cost issue. i found a good rearend [no posi] for $175. thats my maximum budget right now
post #7 of (permalink) Old 07-25-2003, 02:07 AM
MudweiserXJ's Avatar
Where bouts are you located, I have a 4.10 rearend not sure if posi(will be a week or more bfore I can get to check it out. It is from a 95 S-10 w/127,000 miles.
MudweiserXJ is offline
post #8 of (permalink) Old 07-25-2003, 12:54 PM
killabeez
i forgot to mention mine was actually 4.11. i was thinking about swapping the posi but a friend told me the housings are different and i can't swap it in to an open carrier. is this true?
post #9 of (permalink) Old 07-25-2003, 11:25 PM
Well 4.10's and 4.11 are the same, just like some have 3.54 and 3.55. As far as your posi, I take it you mean a factory limited slip, or do you have a locker installed? Well no you cant use a factory limited slip in an open carrier. Now if you have a aftermarket locker, Yes it can be used in a open diff.
