s-10 lift - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-26-2003, 10:23 PM
s-10 lift
i have a 93 s-10 extended cab, i was just wondering what size of super swampers i could fit on it with a 3inch rancho suspension lift and a 2 inch body lift?
post #2 of (permalink) Old 08-20-2003, 09:25 AM
Re: s-10 lift
Loose you might beable to get away with using 33x10.50x15r
jc
post #3 of (permalink) Old 08-27-2003, 12:46 PM
Re: s-10 lift
Loose
I got a 84 S-10 with a 3in body and about 2in of suspention whitch is about the same as you are doing I was only able to fit 30x9.5R15's I tried the 31's but they rubbed when I made a turn. I don't believe the 93 is much diff. I know the body is a bit diff but I think the wheel wells are the same. I know the undercarage is the same. But just wanted to let you know. Good luck.
Josh [img]images/graemlins/RockOn.gif[/img]
post #4 of (permalink) Old 08-27-2003, 07:47 PM
Re: s-10 lift
I'll throw in another twister, I had a 92 with the T-Bars cranked up and ran 31"s. The only time they rubbed was when I jumped.
c_rock is offline
post #5 of (permalink) Old 08-28-2003, 08:04 PM
Re: s-10 lift
you can go with 31 10.5 and be just fine and if you don't mind a little rub then 32's will work but if you go 32's you might start thinking about regearing. redtoy92 [img]images/graemlins/RockOn.gif[/img]
redtoy92 is offline
post #6 of (permalink) Old 09-12-2003, 06:17 PM
Re: s-10 lift
For wider tires you need to changes your rims offset.
post #7 of (permalink) Old 09-25-2003, 12:50 AM
Re: s-10 lift
The 3" Rancho suspension lift was discontinued but is comparable to the Trailmaster 5" lift. That alone should fit 33's on a 1st gen S-10 with no fender trimming. Add the body lift and some trimming and 35's fit easily. The Rancho lift looks sturdier than the Trailmaster in my opinion too.
Jamus is offline
