Re: Electrical Problem?
alot of factory radios have dimmers in them to, after market usualy don't, the wire might be floating around or you may even be using the dimmer wire for the radio as a ground on mistake, many do because it is a ground wire but not intended for power source grounding. take the radio out and see if the wire is taped up and if it is then you are good on that. if you can't find it, then you or who ever hooked it op accidently used it. That is were I would go next! let me know if this doesn't help. I may have a few more ideas.
