Water in engine oil - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-22-2002, 04:48 PM
WhompBigJeep
Water in engine oil
My dad has a chevy s-10 (86) that looks like it is getting water in the engine oil. It also appears that water/antifreeze is being burned in the exhaust. When you fill the radiator, you can only drive 20/30 minutes before the truck overheats, but no leaks. How is the water getting in the engine/exhaust? And how can we fix it?
Thanks in advance.
post #2 of (permalink) Old 08-22-2002, 05:00 PM
Re: Water in engine oil
There are several different places that you could be getting water in your oil. All of them are BAD.
Somewhere or another you either have a hole in the water jacket (the passages that keep water flows through the engine to keep it cool) or you've blown a head gasket (which is actually less serious than the hole in the water jacket.
Either way you *might* be looking at some extensive repairs.
It would probably be a good idea to do a compression test? Check to see if there is an obvious place where the head gasket would be blown.
J.R. is offline
post #3 of (permalink) Old 08-22-2002, 09:05 PM
Carpal \'Tunnel
wrath's Avatar
If it's a 2.8L then chances are it has a cracked head. There is a lesser chance it has a bad head gasket.
I'd pull sparkplugs and find out which side it is then pull that head off.
I almost forgot. If you've been driving it long like this then chances are every bearing in the motor is shot. It's not quite as bad as driving a motor around with an extra quart or two of gasoline but almost as bad. If you've been repeatedly overheating it then it's even worse.
wrath is offline
post #4 of (permalink) Old 08-26-2002, 10:03 AM
WhompBigJeep
Thanks for the info. Those are the things I suspected it might be. Yuk no matter what.
So I assume I should check the plugs and look for abnormal wear? To show if it's been getting water in a cylinder? And if so, I would need to pull the head at that point to check the gasket and check for a crack?
Thanks again!
post #5 of (permalink) Old 08-26-2002, 10:29 AM
Carpal \'Tunnel
wrath's Avatar
Well, the plugs can tell you which cylinder it is. Water can do some crazy things. It can break electrodes off and cause insulators to go AWOL. No matter what, it'll look different. Hopefully you'll just have a discolored plug then it's not too serious.
I check the plugs for several reasons:
It'll tell you what head to pull.
If the spark plug is severely damaged then chances are there are messed up valves/seats and maybe a pistion top. Perhaps even a scored cylinder wall (read: expensive fix). If it's been detonating at the wrong time for a while it can cause wrist pins to become ruined.
If the plug shows little change from normal then it is, hopefully, not too bad. That means maybe as little as a head gasket or as much as a new head.
wrath is offline
post #6 of (permalink) Old 08-28-2002, 11:09 AM
WhompBigJeep
I pulled the plugs last night - one looks like it's got rusty water baked on to it (the inside of the radiator is VERY rusty) and one other one looks like it has oily water on it and smells like anti-freeze. The motor is a four-cylinder so I assume there is only one head. Do I just yank it off, check for cracks and re-gasket it? Thanks again for the help. I've done lots of work on my Jeep, but this is all new stuff for me.
post #7 of (permalink) Old 08-28-2002, 11:53 AM
Carpal \'Tunnel
wrath's Avatar
Ah, the 2.5L. Good motor, no horsepower. The fool-injected ones made 92 horses.
Yeah, there's only one head. You can either buy a new one at an auto parts store or go to the junkyard. Hopefully it's just a gasket though. I've only heard of one 2.5L with a cracked head and that's because the guy was a moron.
wrath is offline
