EGR keeps clogging up - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-14-2002, 03:15 PM
Hey how do you get rid of that deposit stuff that keeps clogging up your EGR Valve?
post #2 of (permalink) Old 06-15-2002, 08:06 AM
Re: EGR keeps clogging up
I kinda don't understand. Do you mean to say that you're continually getting the EGR clogged up enough to stop working?
If that's the case then you have some interesting other problems going on in your engine, and it's blowing it through the EGR and exhaust!
J.R. is offline
post #3 of (permalink) Old 06-17-2002, 09:09 AM
Sorry not tooo descriptive on this matter.It`s a "86" S-10
pickup 4X4 that keeps on comming up code 32.I`ve replaced the EGR valve and got a EGR solenoid from a wrecking yard.
I start up the truck and she runs great,I go about a mile down the road and the Service engine soon light comes on.
I mean the light just bothers me cause it`s on and I can`t figure out how to repair the problem. This weekend I remove the EGR valve and sprayed some carb cleaner in there,and started the engine and she rapped out!shut her down quick
and replace d the EGR valve. it does the same thing .
I am running out of options,do you have any?
Thanks J.R.
post #4 of (permalink) Old 06-17-2002, 09:57 AM
Makes much more sense now!
Keep in mind that troublecode never really point DIRECTLY at the problem; it just gives you a place to start.
If you can perform a vacuum test on the EGR and it does what it's supposed to do than this is not your problem! Putting vacuum on the EGR should cause the engine to go nuts, stumbling and all if I remember correctly.
I would also look into some other options that deal with the surrounding systems. If <font color=red>Hammerdown</font color=red> is still online he might be able to help you out better!
J.R. is offline
post #5 of (permalink) Old 06-17-2002, 10:29 AM
Thanks for the input J.R. I`ll try to get with Hammerdown after I purchase a Vacumm pump and try out what you said.
thanks again!
post #6 of (permalink) Old 07-10-2002, 07:57 AM
I have a '94 s10 4x4 blazer. I've replaced the EGR valve FOUR times. Carbon deposits are getting into the valve, causing it to stick open. When this happens, the engine loses its vacumn and runs like crap (especially at idle). Yesterday, I had both pieces of the intake manifold cleaned out and a new EGR valve installed. Within a 5 miles test drive, the valve stuck AGAIN! I've tried to get at the root cause of this carbon build up, and the service tech says its just the BAD GAS here in OHIO (BS?) Any Ideas?
post #7 of (permalink) Old 07-10-2002, 08:54 AM
I`ve only replaced mine once and picked up a solenoid at a junkyard. I`ve picked up the valve at Shucks. I wonder if I went to a Chevrolet parts dept and bought a new valve would correct the problem.I`ll try to talk to a mechanic and see if he can solve our problem too!
post #8 of (permalink) Old 07-10-2002, 11:42 PM
Mine became Stuck Wide Open, and the guy at the shop just closed it permanently, actually runs better now [img]images/icons/smile.gif[/img] why would you be worrying about it, i get better mileage and power on my S-10 with it stuck closed
Drey is offline
post #9 of (permalink) Old 07-11-2002, 06:25 AM
I considered this and did a little research. With the valve shut during acceleration (when it should be open) combustion chamber temperatures will rise above normal operating levels, causing preignition and associated "pinging" and "knocking". Did you experience any of this when you closed yours?
post #10 of (permalink) Old 07-11-2002, 10:23 AM
Does your service engine light stay on? and how did he
keep it permanently closed?
