Re: S-10 Blazer/GMC Jimmy
If you do go out and get this truck there are some things you should look for, but I notice on these trucks is that you should look at the body mounts and frame I noticed on these that they do let go just like in mine I only notice the mount is broken when someone gets in on the passenger side.besides that check the oil and lubricants in you motor,transmission,rear-end,and transfer-case, if they look beat up and burnt I`d ask some questions. check out front end see that it`s not all beat to piss and loose(axles, c.v. joints,)and foremost put it in 4x4 and take a drive and don`t be afraid to change gears a lot from high to low listen to the axles see if they knock(wheel turned all the way in drive and reverse) and remember it`s not your truck yet if something breaks it`s
better that it happens now then after you sign all the papers.
I`d rather push a Chev than drive a Ford
Hachey, 88 Blazer 4x4
