Got a 4x4 S-15 question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-30-2000, 09:47 PM
what is the possibility putting a Dana300 T-fer case in my '88 2.8l pickup? anybody know the pros and cons of swapping in this unit? does it have the same shift pattern as my stock t-case (2h-4h-n-4l)? will it mate up with my GM stuff, and what are the gear ratios? i also wanna do a Dana44 (early bronco with disc brakes) conversion, would my engine have the balls to push it all? im running 31's BTW. help me out here.....
thanks,
MeatLoaf
post #2 of (permalink) Old 01-30-2000, 10:45 PM
Re: Got a 4x4 S-15 question
I could have sworn that the D300 t case had the front output shaft passenger side, so if that is true, it's not do-able on the GM IFS setup, because the IFS has the front output on the driver's side... Now I think it'll be a very good unit to use, probably nearly bullet proof... I'd guess it has a low range ratio of around 2.6 or so, but I think there's a kit that can reduce it to 4:1(?) I believe in high range it's 1:1... The engine would be able to push it, if, and it's a decent sized "if", you get it properly geared... With a smaller engine, like a 2.8L, gearing means a whole lot, and is the difference between moving good, and losin' drag races to deceased snails ([img]/wwwthreads_images/icons/laugh.gif[/img] [img]/wwwthreads_images/icons/wink.gif[/img]) [img]/wwwthreads_images/icons/crazy.gif[/img].. That's what I know (or think I know) at least...
Tim
"The_Sandman_454"
[img]/wwwthreads_images/icons/cool.gif[/img] '79 Suburban 4x4 454, 6" lift, 35x12.5s & '85 GMC S15 4x4
The_Sandman_454 is offline
post #3 of (permalink) Old 01-30-2000, 11:25 PM
another question
another question......
The NV4500 (from a 1996 dodge 4wd) is a bolt up to the dana300, but is it possible to get a bell housing to connect my 2.8 to the nv4500, or am i asking for trouble? both the dana300 and NV4500 offer superior off-road performance, but i dont know if they fit my application. if you know of a better t-case/tranny combo for my truck, let me know.....keep in mind that it is a daily driver, nothing radical...yet.
Thanks,
MeatLoaf
post #4 of (permalink) Old 01-30-2000, 11:34 PM
Re: another question
Although this would be an awesome setup in one of these trucks, I would guess you'd probably have to fabricate your own bellhousing to go from the 2.8L to the NV4500... [img]/wwwthreads_images/icons/crazy.gif[/img] You might try Advance Adapters maybe send 'em an email to find out... That's about the main adapter place I can think of right off the top of my head...
However if you had a 4.3L or bigger GM small block, I believe they have adapters for the NV4500... I couldn't say totally for sure tho.. If not, the SM465 and NP205 are a good combo, that might be adaptable for you... [img]/wwwthreads_images/icons/crazy.gif[/img]
Tim
"The_Sandman_454"
post #5 of (permalink) Old 01-31-2000, 11:46 AM
another question...again
ok, i think this is the last one......
Did the NV3500 mate to the 2.8? what are its ratios? i think its standard but not sure (?) looking for info. on that as well. will it mate to a dana300? how good of a tranny is it, and is it a worthy transplant?
later,
MeatLoaf
post #6 of (permalink) Old 01-31-2000, 01:31 PM
Re: another question...again
NV3500 M.......4.01....2.32...1.40.....1.00... .73.....Chrysler
The ratios are from 1st to 5th.. I couldn't get the column thingees to work right on here... [img]/wwwthreads_images/icons/crazy.gif[/img]
I found this info on an off road mailing list, not sure how accurate it is, and not sure if the GM version of the NV3500 is similar... The M on the little table thingee is saying it's medium duty... Here's the link to the place I found that info... http://www.offroadlist.com/digests/v6n213.html It is part way down the page...
Also not sure if it'll mate directly to a Dana 300 or if it'd need an adapter... If it wouldn't mate directly, I would bet that adapters are produced for this swap... However I still doubt that this tranny would bolt up to a 2.8L... You'd still have to have an adapter or at least 4.3L to bolt a GM version of it in... Not sure how accurate this is but I'd guess it's about right... [img]/wwwthreads_images/icons/crazy.gif[/img]
Tim
"The_Sandman_454"
post #7 of (permalink) Old 01-31-2000, 02:13 PM
The NV3500 will only fit on the 4.3 V6.
--Drew
83 S10 Ext Cab
[img]/wwwthreads_images/icons/smile.gif[/img]
drew_kay is offline
post #8 of (permalink) Old 01-31-2000, 10:42 PM
okay, i\'m frickin frustrated!
Are there ANY medium to heavy duty tranny's that'll bolt up to my 2.8? (other than the T-5)
i want the dana300 out of a jeep to bolt to it......i also wanna do the bronco-to-S-15 axle swap as well....
that will make the front drive yolk on the dana300 match up with the yolk on the front axle....all ill need is a drive shaft.
Meatloaf
post #9 of (permalink) Old 01-31-2000, 11:57 PM
Re: okay, i\'m frickin frustrated!
I think you'll have to look to the Jeeps to find a decent (medium to heavy duty) tranny that would mate to the dana300 and the 2.8.. I think some of the buick engines found in some Jeeps would have a similar pattern to the gm 2.8, but couldn't say for sure... [img]/wwwthreads_images/icons/crazy.gif[/img] (How is the T5 identified anyway? Is it just the standard/only manual 5 speed that was used behind a 2.8L?)
Tim
"The_Sandman_454"
