"Real World" oil pressure - Off-Road Forums & Discussion Groups
Ford Lounge General discussions and Frequently Asked Questions.
post #1 of (permalink) Old 07-26-2003, 11:37 AM Thread Starter
\"Real World\" oil pressure
I finally had the time to install my oil pressure gauge yesterday. [img]images/graemlins/cool.gif[/img] Yes, my dash gauge is a million miles off! [img]images/graemlins/shocked.gif[/img]
But now that i have actual #s to go by, i was wondering if anyone could tell me if theyre good numbers, or if they are signs of an impending problem with the engine.
Basically, i get 50psi when revving or idling. (at start-up)
Once the engine is up to temp, it will idle at 25psi. The pressure will increase with RPM until i break 2k, where it holds a constant 50psi.
extra info:
The oil in the engine is (new) Castrol 10w40 (has maybe 10 miles on it), and the filter (also new) is a Napa Gold.
reptillikus is offline
post #2 of (permalink) Old 07-26-2003, 01:54 PM
Re: \"Real World\" oil pressure
That's fine Kev, general rule is 10 psi for every 1000 RPM.
Did you try changing the sending unit first? My 89 started acting up out of the blue. Though I was gonna puke an engine. I changed the sender when I did the timing chain and it's back to normal.
MY2ND78 is offline
post #3 of (permalink) Old 07-26-2003, 02:49 PM Thread Starter
Thats good news to my ears! I had a feeling it was ok, but i needed to make sure. And i knew someone here would have an answer for me! [img]images/graemlins/grin.gif[/img] (Thanks Al!)
I replaced the sending unit a couple months ago, and the same problem came back right around when my timing cover gasket started leaking two weeks ago, which is when i ordered for the Autometer gauge.
I was digging through Mitchell earlier and found a TSB for ~88 trucks where the sending unit and resistor wire didnt work properly, and the gauge would read erratically, like mine was doing. They apparently issued a different sending unit and 20ohm resistor wire to correct it. Shame i didnt think to look this up earlier, i wouldnt have stressed as much over it!
But anyway, right now i did some plumbing, and have both senders (OEM and Autometer's) in. I eventually want to figure out a way to fool the dash gauge so that it wont trip a CEL like it has been doing on and off today/yesterday.
post #4 of (permalink) Old 08-01-2003, 04:48 PM
Shilo
Dude just ground the stock wire that went to the stock sending unit. This tells the ECM you've got oil pressure and eliminates the CEL. And your numbers are great! I get 19-20 lbs at hot idle with less than 50,000 on my motor.
post #5 of (permalink) Old 08-01-2003, 07:13 PM Thread Starter
Ok, cool...i wasnt sure if i could ground it or not....i thought that maybe it would freak out if i did. I guess not!
Now if it ever stops raining ill have to go do that! Thanks Shilo
