351 Windsor rebuild - Off-Road Forums & Discussion Groups
Ford Lounge General discussions and Frequently Asked Questions.
post #1 of (permalink) Old 06-05-2003, 11:32 PM
351 Windsor rebuild
I just picked up an '85 Bronco with a 351 Windsor for $1000. Clean inside, 4x4 seems to be in good shape, runs good except for one little problem. The engine has near 150,000 miles on it and suffers from a little blowby problem, to the tune of about 1 quart every 100 miles or so. It does not smoke or burn oil. Unless you count the stuff that is dripping onto the exhaust manifold. So I figure I would like to replace the heads.
Is this a good place to start?
What are the best heads to buy?
As long as I am in there should I also replace the cams?
Is it even worth it?
I would like to turn this into a nice 4x rig and can take things apart and put them back together prety good and time is not really a problem.
So I figure for $1000 plus the cost of heads I will have a darn near brand new engine.
As you can probably tell I am new at this whole thing. The most serious surgery I have personally done is to replace the front main seal and h2o pump but I do not think swapping out the heads is anything that I can not do.
Is this enough to get you started? [img]images/graemlins/confused.gif[/img]
post #2 of (permalink) Old 06-06-2003, 02:04 PM
Pooh-Bah
WD40's Avatar
Re: 351 Windsor rebuild
Blow-by is usually caused by worn rings, not worn heads.
The term blow-by is coined from compression "blowing by" the pistons.
Personally, I wouldn't spend the money on new heads only.
Do that, and the new-found compression from better sealing valves,
will most definitely fry the rings, and won't help the mains or rod bearings either. [img]images/graemlins/frown.gif[/img]
Have you checked the PCV valve lately? Could be plugged.
Do yourself a favor, and perform a compression check first.
Get a leak-down tester, (some stores will loan or rent them) and see what shows up with that as well.
Once you have compression and leak-down numbers, you'll get a better idea of what components are worn.
I'm a firm believer in the rebuild everything at one time only philosophy. [img]images/graemlins/wink.gif[/img]
You're only asking for trouble if you do it "piecemeal" style.
Welcome to the forum by the way! [img]images/graemlins/grin.gif[/img]
WD40 is offline
post #3 of (permalink) Old 06-16-2003, 04:06 PM
Amen! [img]images/graemlins/smile.gif[/img]
TheJuice is offline
post #4 of (permalink) Old 06-24-2003, 11:49 PM
you can buy a reman motor from advanced with heads and a 18 mounth warranty for 850.00 plus core charge
80BRONCO is offline
post #5 of (permalink) Old 06-25-2003, 09:33 AM
how 'bout a long block w/ a 7yr, 70k mile warranty for $1160 here
hitechredneck is offline
