Block Lift Question?? - Off-Road Forums & Discussion Groups
Ford Lounge General discussions and Frequently Asked Questions.
post #1 of (permalink) Old 02-25-2003, 07:33 PM
Can i use blocks to lift the front as well as the back? (with a solid axle of course)
post #2 of (permalink) Old 02-25-2003, 08:07 PM
Re: Block Lift Question??
no
BurnedBronco is offline
post #3 of (permalink) Old 02-25-2003, 09:14 PM
What's the reason? I've seen tons of chevy's with blocks up front
post #4 of (permalink) Old 02-25-2003, 09:23 PM
its not safe enough. I will leave it at that.
post #5 of (permalink) Old 02-25-2003, 09:26 PM
thanks for all the help........................
post #6 of (permalink) Old 02-25-2003, 09:57 PM
muddybronco's Avatar
because when you hit the brakes all your truck's weight shifts forward over the front axle, and those blocks create lots of leverage on the axle housing. that results in a ton of torque on the axle, which can bend/break springs, snap driveshaft ujoints, and make your steering worthless. even rear blocks can do the same things... i had a 5.5" block pop out on the trail and it let my axle drive under the truck, which ate the hell out of my fender and tire. if you want to lift a leaf axle without spending money, figure out how to drop the leaf spring mounts on the frame.
muddybronco is offline
post #7 of (permalink) Old 02-28-2003, 07:06 PM
While were on this topic, what about reversing the rear shackles (the stock ones)
post #8 of (permalink) Old 03-01-2003, 08:38 AM
It would create a pinion angle that points so far down that i doubt youd even be able to attach the front driveshaft. And if you did, youd probably break a ujoint as soon as you put it in 4wd
reptillikus is offline
post #9 of (permalink) Old 03-01-2003, 08:57 AM
Im glad i asked that question , I was just going to try it out .thanx Rep
post #10 of (permalink) Old 03-01-2003, 10:56 PM
i purchased a 85 chevy shortbox to replace my rusty 76
chevy shortbox, i used parts from each to make one good truck, the 85 had front 2" blocks, when i went to remove them ,they where broke in half, only held in by pressure,
im sure glad i pulled them out before they flew out, on
there own, (death trap) [img]images/graemlins/cussing.gif[/img]
