- Ford Early Bronco, 66-77
(https://forums.off-road.com/ford-early-bronco-66-77/)
- - small block ford
(https://forums.off-road.com/ford-early-bronco-66-77/39488-small-block-ford.html)
small block ford
1970 302-rebuilt-
new rings, bearings, high volume oil pump, reworked heads, timing chain, hp cam/lifters, everything. Sell for $500 for the short block or $700 for the long block. 1974 302-rebuilt- bored 0.040", new rings, bearings, high volume oil pump, reworked heads, double roller timing chain, Comp Cams cam/lifters, everything. Sell for $800 for the long block (includes all tin) 1986 5.0L-rebuilt- new rings, bearings, high volume oil pump, reworked heads, timing chain, cam/lifters. Complete from oil pan to intake manifold. Also has the fuel rails and injectors- $1200/obo with stock cam or $1450/obo for aftermarket cam. Also includes engine wiring harness and computer. '95 Ford Ranger, 347cid engine, NP435/Dana 20 (3.15:1 gears), 4.88 Powerlock Dana 44 front, 4.88 Strange spool 9" rear, Wrangler springs in front, 38X15.50X15 TSL Swamper Radials |
Re: small block ford
Are you willing to part out the Ranger, I.E. Axles and gears etc?
http://smilecwm.tripod.com/ut2/camper.gif [img]/wwwthreads_images/icons/tongue.gif[/img]My Drinking Team Has A Rockcrawling Problem[img]/wwwthreads_images/icons/tongue.gif[/img] |
Are you on CRACK? Where did you see anything about parting out a Ranger, especially my wheeler. That truck will never be parted out. It's a one of a kind, first Ranger ever built like it is. You might want to re-read the post. Just cause it got stripped doesn't mean you get rid of it. You fix it and keep goin'.
User Alert System provided by
Advanced User Tagging (Pro) -
vBSecurity v2.2.2 (Pro) -
