-   Ford Early Bronco, 66-77 (https://forums.off-road.com/ford-early-bronco-66-77/)
-   -   Knuckle removal on Dana 44 help (https://forums.off-road.com/ford-early-bronco-66-77/35620-knuckle-removal-dana-44-help.html)
**DONOTDELETE** 08-23-2000 10:06 AM
Ok I'm in the junkyard and trying to get the knuckles out of a '78 Bronco for my '76 44 I just bought. Under the castle nut is another adjustment (?) nut on the top half, does this need to come off? What is the procedure for knuckle removal? HELLLLLLLP!
**DONOTDELETE** 08-23-2000 05:10 PM
Re: Knuckle removal on Dana 44 help
no, it doesn't have to come out. It is turns to allow camber adjustment(the hole is slightly off-set). the best advise I can give is"GET A BIGGER HAMMER" if that doesn't work then apply heat"torch" to the axle housing around where the ball joint stud sticks out. This should help but your still going to HAVE to use a HAMMER.
Frank
