Lock out hub swap problems, need help - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-22-2001, 01:57 AM Thread Starter
We were going from factory auto hubs to warn permium lock outs on a '93 ford ttb d44 and the inner adjustment nut (it takes a 4 prong socket) got stripped, you can tighthen the nut but loosening it is a lost cause it was susposed to be a square slot but the side to loosen it is rouned off and the 4 prong socket just slips off. we tried using a file to make them squrare again and that was a lost cause. We are thinking of just try to cut the nut off (major pita) or maybe to cut new slots with a dreml. Help, give us ideas we need to get this done quick, we want to go wheeling tomorow.
Thanks in advance,
BarrelRoll
97 TJ
Wheel it or drive a minny van
Jeeper99xj is offline
post #2 of (permalink) Old 12-22-2001, 03:44 AM
muddybronco's Avatar
Re: Lock out hub swap problems, need help
that is strange because the inner nut is not supposed to be very tight. are you sure you've got all the fasteners off? Is it the two nuts with a keyed washer sandwiched between? I just cant see how you put enough torque on it to round off all 4 slots, unless maybe the socket you're using isn't the right one. Mine fits like a glove, no slack at all. I would try giving it a couple good whacks parallel with the spindle, it must be cross threaded if it's that stuck, but those are fine threads so that seems unlikely. It's gonna be a bitch getting a dremel in there, you'd probably be better off trying to drill a hole in there and then using a punch to work the nut around in a circle. I'm not sure but something sounds fishy. good luck.
S H O U L D A G O T T A F O R D!
www.ArkansasMud.com
muddybronco is offline
