Gasket sealant? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-15-2001, 01:48 AM
Gasket sealant?
Do any of you guys have reccomendations on a good sealant. I gotta get a new intake manifold gasket but untill I save up some cash I was thinking about using one of those additives ya put in the radiator. I don't want to put anything in there that might mess anything up. The leaks are really small so do you guys think I should just wait untill I have the cash or would a sealant be a good quick and temporary fix? Is there any bad side affects of using one of these products?
post #2 of (permalink) Old 12-15-2001, 12:31 PM
BRONCOMANIA's Avatar
Re: Gasket sealant?
Theres a lot of different brands and types but as long as you dont get carried away with that stuff(like adding it once a week) you should be ok. Remember though, not all of them are compatible with coolant so read the label and use as directed. If it might be a while before you get the opportunity to fix it right, i would find one thats compatible with coolant. Sorry, dont know the brands that *are* off hand.
BRONCOMANIA is offline
post #3 of (permalink) Old 12-15-2001, 03:27 PM
Re: Gasket sealant?
Thanks! I'll keep that in mind.
post #4 of (permalink) Old 12-17-2001, 02:27 PM
Pooh-Bah
WD40's Avatar
Re: Gasket sealant?
I've used Aluma-Seal with some semblance of success.
I'ts (like the name says) powdered aluminum.
Just pop the rad-cap and pour in the radiator.
Comes in a plastic container about the size of a roll of quarters.
Repaired a water pump gasket leak.
I left the sealant in for a year before fixing the water pump properly.
It never did leak after using 1 "dosage" of the stuff.
WD-40 Reverend Grip-Shift
85 Bronco XLT, '69 351W, C6-Shift Kit, 9"-Detroit, Dana 44-Tru Trac, 2" Lift, 33X12.5s
WD40 is offline
