T-case won't engage - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-03-2001, 05:23 PM
T-case won\'t engage
Push button system. 4x4 light does not come on and no clunck (engagement) is heard. It does seem like a relay in the cab is clicking? Oh, it is a Borg Warner 13-56 T-case.
Is the soleniod on the T-case the most likely suspect?
[img]/wwwthreads_images/icons/cool.gif[/img] MG48 - 88 Bronco
post #2 of (permalink) Old 12-03-2001, 08:45 PM
muddybronco's Avatar
Re: T-case won\'t engage
yeah, pull it off and see if the grease hardened and got into the contacts. pull the motor support bracket off, then there are three hex bolts holding the whole assembly on. there is a little access plate held on with torx screws, dont remove it. it is sealed from the tcase so dont drain the fluid. good luck. it could also be the brushes on the commutator, if you take that part of the motor apart, be prepared to loose the springs that push the brushes out, they come out with some speed!
Your Toy is loaded huh? Does it have Power Engine?
<A HREF="http://www.arkansasmud.com/" target="_new">
ArkansasMud.com</A>
muddybronco is offline
post #3 of (permalink) Old 12-04-2001, 10:38 PM
i dont have the same problem, only in 4 low i think. i also have the garbage push button, and it engages 4hi real good. when i stop, put it in neutral, and press low range it just flashes. i'm not familiar with these electronic transfer cases, and i dont notice any difference when i drive with it flashing. anyone have this same problem, or know how its supposed to work?
kyle
post #4 of (permalink) Old 12-05-2001, 09:44 AM
If the 4x4 low light is flashing then it is not engaging low range.
post #5 of (permalink) Old 12-05-2001, 11:06 AM
Try this, I read it on the board about a year ago and it worked for me. While someone is in the truck pushing the button, get under the truck and lightly tap the solenoid with a small mallet (preferable rubber). If this works, make it a practice to engage the 4 wheel drive system often (about once every two weeks) so that the solenoid does not freeze up on you again. I have been going for a year now, with no problems.
ridinghigh's barn
93 bronco EB 302 32'BFG AT
98 suburban
86 hydra-sports 200 Merc (my other hobby)
post #6 of (permalink) Old 12-05-2001, 03:52 PM
Haha, yeah I did that for a LONG time before I got around to disassembling everything... worked great except nobody would volunteer to climb under the muddy bronco to tap on it for me.
When I gun this three fifty one, you better run!
www.ArkansasMud.com
post #7 of (permalink) Old 12-05-2001, 04:14 PM
I only had to do it once, and it has been working every since. My theory is if it ain't broke, it works. I did remove the torx as you stated and cleaned the brass with alcohol. Maybe that did it.
ridinghigh's barn
98 suburban
post #8 of (permalink) Old 12-05-2001, 08:55 PM
So would hitting the solenoid with a rubber hammer while pressing the lowrange button possibly solve this?
post #9 of (permalink) Old 12-05-2001, 10:51 PM
Might solve your problem (by trying to put it in low range)
Havack!
The main difference in my truck and yours is your truck is a toy and my truck is a truck!
havack is offline
post #10 of (permalink) Old 12-07-2001, 10:09 AM
It is worth a try. If it does not work, Take the module (solenoid) off and see if you can manually turn the knob. You should be able to do this with a little effort. If you can, then try to clean module as Muddy pointed out. If it still does not work, you probably need a new module. If you can not turn it, I would assume that something is wrong with the T- case.
ridinghigh's barn
98 suburban
