Small added lift for rear - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-28-2001, 07:57 PM Thread Starter
Has anyone heard of using ford 3/4 ton shackles for a small added lift to the rear? I am looking for only about 3/4 inch. Would like to level the rear with the front and want an easy way.
The Juice, '95 Ford Bronco XLT, White, 5.8, E4OD, 4" Rancho, 35's, 4.10, ARB/LSD, lots else
TheJuice is offline
post #2 of (permalink) Old 11-29-2001, 09:16 AM
Shilo
Re: Small added lift for rear
W/the stock setup longer shackles will lower the truck in the rear. Shorter shackles would raise it somewhat (barely) but other problems might arise, never looked into that. Keep in mind shackle lifts provide 1/2 the amount of change in shackle length, i.e. shackle 1.5" shorter will lift 3/4". Again, I've never heard of anyone going to shorter shackles for lift. I'd use a 1" block unless you're already using blocks.
post #3 of (permalink) Old 11-29-2001, 11:33 PM
My bro's s10 blazer squatted in the rear real bad, so he got a 2" add-a-leaf. Now it looks bitchin[img]/wwwthreads_images/icons/cool.gif[/img]
Tom
Climb in, hold on, Lets rock and roll!
[email protected]#$%^&* open Diffs.
post #4 of (permalink) Old 12-03-2001, 01:34 PM
the only reason a longer shackle would lower the truck, is because ford uses a reverse shackel rear perch. if you bust the rivets off the shackle perch, and weld/bolt it on the other way, that would lift you , but i imagine more then the 3/4 of an inch that you seek. if you find a reasonable way to lift it, i would like to know, as i am seeking the same thing right now. i have ordered two block kits, btu niether one fit the bronco. my camber will never be right, until i can get that ass up in the air once again.
Dominic
"MUD BUCKET" 1984 bronco, 88 302, 32x11.5 , I am at screen name iskybantilus on instant messenger.
post #5 of (permalink) Old 12-03-2001, 02:29 PM
Pooh-Bah
WD40's Avatar
I used Rancho 1-1/2" to 2" add-a-leafs, but removed the stock leaf that was the same length as the add-a-leaf.
Netted me 1" lift after all was said and done.
Rides a little harsh though.
<font color=blue>All I want for Christmas is a set of soft-ride shackles!</font color=blue>
WD-40 Reverend Grip-Shift
85 Bronco XLT, '69 351W, C6-Shift Kit, 9"-Detroit, Dana 44-Tru Trac, 2" Lift, 33X12.5s
WD40 is offline
