carb? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-22-2001, 01:31 PM
carb?
i think my carb is screwed. i have a 86 w/ the 300. we just got a rebuilt carb not too long ago. ive been having trouble with it sputtering and stalling mostly right when it starts up and shortly after about 10 min. also, the valve that you can see when you take the air cleaner off is like stuck open. it seems like some linkage broke because it moves very easy but it just flops around if you know what i mean. it doesn't spring back when you move it or whatever. its wide open and now my truck is idling really fast and wasting a lot of gas. also, sometimes after i turn it off, when im trying to start it back up again the valve is stuck shut and it wont start so i have to stick something down it to keep it open then it starts but barely. also it's been backfiring like once a day and it never used to. do i need a new carb or what?
post #2 of (permalink) Old 11-22-2001, 04:43 PM
Re: carb?
Looks like your choke is broker you need to get it fixed a carb. shop should have the parts you need good luck Bill
post #3 of (permalink) Old 11-25-2001, 12:45 AM
Steve83's Avatar
Choke
You didn't get the choke spring hooked back into the choke shaft when you put the cover back on. It's under the electric assist, retained by three screws (rivets originally) behind the plastic divider plate. It all has to be assembled in the correct order & orientation to work right, so check the diagram that came with the rebuild kit. Then follow all the steps in the kit (in order) to bench set the carb, and follow the steps on the emissions sticker on your core support to set it on the engine.
[email protected]
Steve83 is offline
