How hard to change radius arm bushings? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-19-2001, 08:40 PM
What is involved in changing my radius arm bushings on my 84 Bronco? Never done it before.
post #2 of (permalink) Old 11-19-2001, 11:08 PM
Re: How hard to change radius arm bushings?
easy way is to pop out the rivets off the brackets and bolt them back on easy to do if you have good air chisels
post #3 of (permalink) Old 11-20-2001, 12:39 AM
Steve83's Avatar
I've always unbolted the shocks, springs, sway bar, & calipers, and pulled the TBs forward until the radius arm clears the bracket. Then I just let it go back in & put everything back on. I've done 3 sets that way.
Unless you get bolts that fit the rivet holes perfectly & torque the $#!t out of them, the brackets may shift while you're hammering across the washboards & clipping curbs.
[email protected]
Steve83 is offline
post #4 of (permalink) Old 11-20-2001, 04:31 AM
What's a TB? I am about to replace my radius arm bushings and sway bar bushings with polyeurethane.
post #5 of (permalink) Old 11-20-2001, 07:22 AM
Steve83's Avatar
Oops
TB=Traction Beam, from TTB for Twin Traction Beam
[email protected]
Steve83 is offline
post #6 of (permalink) Old 11-20-2001, 01:59 PM
zakt's Avatar
my 1980 broncos radius arm bushing mounts had bolts so just removed them to change out the bushings... then my 1980 had the rivets ....
One of the broncos....
zakt is offline
post #7 of (permalink) Old 11-20-2001, 11:10 PM
I just ordered the poly bushings for the radius arms and going to change the bushings on the sway bar as well. I'll let you know how it goes.
post #8 of (permalink) Old 11-20-2001, 11:51 PM
Steve83's Avatar
Poly
You might as well do the end links, if you're doing the sway bar bushings. And while you're down there, you could do the axle pivots, too. If you have some time, I also recommend body mounts and, for the really gung-ho, the shock bushings.[img]/wwwthreads_images/icons/smile.gif[/img] (No, I haven't done mine.)
(The ones I bought didn't fit.)[img]/wwwthreads_images/icons/blush.gif[/img]
[email protected]
Steve83 is offline
post #9 of (permalink) Old 11-21-2001, 12:52 PM
I used a dremel tool to cut off as much rivet head as possible and then cut the rest off with a chisel. I bolted everything on with grade 8 bolts, nuts, washers and lock washers. Not too hard just time consuming.
post #10 of (permalink) Old 11-21-2001, 04:56 PM
BRONCOMANIA's Avatar
I just took the radius arms out when i did mine,(cause i didn`t have stands tall enough to pull the axles forward very far like steve does). It wasn`t that difficult but i have an air compressor and all air tools.[img]/wwwthreads_images/icons/smile.gif[/img]
The only tough part was aligning the bolt on the "bottom" of the beams under the coil spring, but i still did them in under 4 hours...
BRONCOMANIA is offline
