Re: Strange thing?????
I'm assuming that your XLT has a tilt column. There are u-joints in it, and although I've never seen one go bad, there's always that possibility. Do you keep it straight in line, or tilted? Does it happen every time you steer, or only under certain circumstances (driving low speed, driving high speed, stopped, etc.)? Does it alway occur when the wheel is turning across the same position (4-o'clock, etc.)? Have you looked at the rag joint?
Steve
