Ball Joint update - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-12-2001, 11:24 AM
Ball Joint update
What a job! A simple task turned nightmare. I have changed a lot of ball joints in my life, I was a mechanic in the army for four years, worked on hummers, 2.5 - 5 ton trucks and a lot of different tanks. I have never experienced anything like I did this weekend. 15 year old ball joints SUCK! First of all, the nut on the lower ball joint, broke my Craftsman ratchet with a cheater bar on it, didn't budge. No problem, I run to sears, exchange ratchet and buy 1/2" drive breaker bar. Oh yeah, all along I was applying heat from a propane torch. Get home, use breaker bar and 3 foot cheater bar..............Boom, something breaks, its not the nut but the edges on the nut. OK, now I move on to acetylene, get the joint glowing red hot and get the nut off. Not too big a deal. Both balljoint nuts removed, I keep remembering what the manual said, watch the knuckle, it will fall right off on your toe. I WISH. Knucke will not budge, sledge hammer, will not budge, oxy-acetylene and sledge, will not budge, at this point the grease in the ball joints is boiling and the boots are on fire. Finally, a pickle fork between the nuckle and axle gets it to drop. The holes in the axle were deposited with metal from the years the ball joints spent in there, in othere words, the joints were welded in place. After that, the job was a breeze and everthing went together quickly. The ball joints came out and went in easily with a ball joint press and air impact, man I love air power tools! All and all, it was a simple job turned night mare by 15 year old parts. The lesson learned? Be harder on your vehicle so you are forced to replace parts regularly, that way they wont be "welded" in place. hehe
post #2 of (permalink) Old 02-12-2001, 01:41 PM
Steve83's Avatar
Can you say \"Anti-Sieze Compound\"????
I hope you slathered it up with this stuff when you put it back. It's like $8 for a ~10oz. bottle of Perma-Tex, and I'm still on the first bottle I bought 2 years ago. It's recommended for oxygen sensors and other exhaust fasteners, lug nuts (steel and aluminum rims), U-bolts, head bolts, etc., but I've put it on EVERY machine-threaded fastener I've worked on since I got the stuff. Now, EVERYTHING is easy: front spindles, water fittings, frame bolts, camper shell, fenders, steering column, brake bolts, ad nauseum...
I HIGHLY recommend it.
Steve
Steve83 is offline
post #3 of (permalink) Old 02-12-2001, 09:46 PM
Re: Can you say \"Anti-Sieze Compound\"????
Steve
I'm gonna try that Perma-Tex stuff. Hope I can get it in Canada.
Brad
I hear you on the misery. I usually farm out ball joints on cars, never mine trucks. I've got a trick for you for next time a nut seizes on you. Many shocks I've changed on my Mopar cars used to drive me nuts as the nuts on the stems always "bond" or "become one" with the stems. Last Summer I was doing the fronts and there was limited room, up inside the fenders, to get my favourite hitting tools in there to beat the bee-jeezus out of them, so I whipped out the Sawzall.
Cut the flats off each side of the nut and flick the remaining pieces off with your finger. It worked for me ! The only other trick I can offer is use a large enough pickle fork and place it so you can get your biggest hammer in close for a really good sharp RAP! repeated hammerings don't work as well as one really good sudden rap.
Malcolm
Sixlitre is offline
post #4 of (permalink) Old 02-12-2001, 10:30 PM
Steve83's Avatar
Liquid Wrench saves knuckles, too, and it's cheaper than a Sawzall. I've always found using a hammer to vibrate parts (especially after rinsing them with Liquid Wrench) to be VERY effective, and less traumatic to the parts than one vicious smack. My aim is terrible when I swing that hard, anyway.
Steve
Steve83 is offline
