exhaust survey - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-08-2001, 09:44 AM Thread Starter
exhaust survey
Well I got my Exhaust figured out. I call the shop where I got my vortex cat back system and they are going to fab me a "Y" pipe for my 1996 5.8L engine that I dropped into my 1990 bronco because the '96 has a different angle. I called the dealer and they quoted me $1500!!!!! because it comes with the converter[f-them]. My guy quoted me $300 that included all flanges and 16 gauge pipe. Sounds like a deal. What do you think? By the way, I had to cut off one of the cats but I'm leaving on the other one just for inspection purposes that was his idea. Of course I'm gonna put a pipe through it first so it will be just for show. NO RESTRICTIONS!! Cats suck!!!!!
Backyard Builder-If I ain't drivin it I'm under it!
slickerthanyou is offline
post #2 of (permalink) Old 02-08-2001, 11:38 PM
Re: exhaust survey
Sounds like a plan
Are you running a large single all the way back ? I replaced the stock tail pipe and muffler with Speedy replacement parts about 3 years ago on the 86 EFI 5.0 litre, but I'm watching what everyone else is using to see what the best system is for when I need to go front to back in a year or three.
I had performed the torturous job of changing the exhaust manifold gaskets last Summer and was surprised how solid that "two pipes into cat stock Y-pipe still was. I wonder what gauge they used, it was rock solid even after 16 years ! I seriously doubt the cat is doing a whole lot after all this time, but we don't have emissions tests up here anyway so like you say who cares.
So far after reading everyone's posts I've got a pretty good idea of what my system will incorporate when it comes time to change out the whole system. Reading everyone's trials with duals and for simplicity and economy reasons, duals are out for me.
The single I aims to go for will start with two oversized pipes off the manifolds bent using the Midas bending cards except I want them ending up one on top of the other for stock style clearance. Summit makes a great flowing two into one adapter that looks more like a header collector, this will be welded in to convert the two 2 1/2s into a full sized 3" system.
At the start of the 3" system a triangular 3 bolt holed flange will be welded in, making sure the pointy end faces up and not down where it might get torn off 4X4ing. Somebody's (the cheapest) 3" high flow cat will have similar 3 bolt holed flanges welded onto either end of it and a another flange will start the 3" pipe that make the run to the muffler.
The jury is still out on the muffler and I'll probably use the best 3" muffler that technology can offer then. I'd kinda like to use a similar cigar shape like the stock one, because I think they look like a "real truck's" muffler, but hey like I said, I'll use whatever is considered the best then.
Lastly I'm either going to graft on a Dodge Cummins 3-4" side exit tailpipe or have a clone built to look like it. These little Hondas with their pee shooter exhausts kill me with their 5" tailpipes but nobody, from any marque, laughs at that honkin' large Cummins tailpipe when their drivers window is level with it at a stoplight. It just screams "yeah, this truck's got the power to tear your Honda in half buddy".
That's my dream exhaust system, this week, good luck with yours
Malcolm
Sixlitre is offline
post #3 of (permalink) Old 02-08-2001, 11:44 PM
Re: exhaust survey
Forgot to add that I'm going to have a flanged "test pipe" made up the same length as the 3" cat in case I need full flow at anytime.
Malcolm
Sixlitre is offline
post #4 of (permalink) Old 02-09-2001, 12:40 AM
Re: exhaust survey
Ain't goin' with duals for two more reasons. Firstly ground clearance and secondly, they still haven't proved that duals are better than a large single for increasing (or more importantly maintaining) low speed torque. I think that's kinda important of a full sized Bronco with only a 5.0 litre motor.
Malcolm
Sixlitre is offline
post #5 of (permalink) Old 02-09-2001, 01:05 AM
Re: exhaust survey
Yeah, the duals with the crossovers have been proven to increase horsepower, (x crossovers, not those crappy h-pipe crossovers), so I think yer right on target, six.
-mike
post #6 of (permalink) Old 02-09-2001, 01:43 PM Thread Starter
Re: exhaust survey
I have single with duals coming from the muffler, I did it for looks more than anything and my chrome extentions are 4inch diameter 18 inches long a bit over done but sounds and looks cool.
post #7 of (permalink) Old 02-09-2001, 02:01 PM
zakt's Avatar
Re: exhaust survey
on my 1980 bronco I have true dual exhaust seperate with a cat on each... I actually bought it that way so dont know what the difference is in pwr vs torque etc... I am planning on getting some new full length headers and changing to flowmaster 2 chambers but keep it true dual...then on my 1981 have the single with a borla but that has a cracked block so havent driven in awhile
zakt is offline
post #8 of (permalink) Old 02-09-2001, 08:31 PM
Re: exhaust survey
Do you have a crossover pipe just before your cats ?
Malcolm
Sixlitre is offline
