It keeps dying when I put it in Reverse - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-05-2001, 11:42 AM
Why does my '93 Fullsize Bronco keep dying everytime I put it in reverse? If I push on the gas, it won't die, but it feels like it hits something, as if the the transmission isn't 'catching' I guess.
I know this doesn't make much sense, but if you have any ideas as to why it might be dying reverse, let me know!
Could it need a tune-up?
It is an automatic, 302, 32" AT's.
post #2 of (permalink) Old 02-05-2001, 02:41 PM
Re: It keeps dying when I put it in Reverse
My '90 did the same thing but it also did it every time you put it in gear forward or reverse. I took it to ford and they put on a new air-bypass switch and TP sensor never did it again. I guess that was the problem. I hasn't done it sense. About 160 bucks later.
Backyard Builder-If I ain't drivin it I'm under it!
slickerthanyou is offline
post #3 of (permalink) Old 02-05-2001, 07:55 PM
Steve83's Avatar
The air bypass (Idle Air Control) is probably the culprit on both trucks.
Steve
Steve83 is offline
post #4 of (permalink) Old 02-05-2001, 11:32 PM
Me too!!!
Whenever I put mine in gear (after warm) it seems to be "slamming" in gear? In the morning, I put it in reverse and it slips right in nice and easy. Go to put it in drive and it slams in gear. (And guys, NO PUN INTENDED) Tranny was serviced, 6,000 miles ago.
Thanks
cmg
1989, 351, C6, 15x10's and 31's
post #5 of (permalink) Old 02-06-2001, 07:56 PM
Steve83's Avatar
Re: slamming!!!
Yours still sounds like a serious transmission problem.What exactly was done when it was serviced? Were the bands adjusted? What did the magnet in the pan look like?
Steve
Steve83 is offline
post #6 of (permalink) Old 02-06-2001, 11:17 PM
Re: slamming!!!
Okay, when I say SLAMMING, I mean it idles up kinda high and then drops into gear pretty hard and it doesn't do it all the time.
As for the service, everything looked in check. I just did the basic fluid/filter change. Didn't notice a magnet? and the bands were not adjusted. Although, it seems pretty easy to adjust them and am probably going to do that this weekend. Do I need to torque everything the way haynes says to do for the bands?
Thanks Steve
cmg
post #7 of (permalink) Old 02-07-2001, 12:02 AM
Steve83's Avatar
Re: slamming!!!
Yes, the torque IS the adjustment.
Steve
Steve83 is offline
post #8 of (permalink) Old 02-07-2001, 08:49 AM
Re: slamming!!!
Okay. SO, do you think that could be my problem?
Thanks
cmg
post #9 of (permalink) Old 02-07-2001, 09:12 AM
Steve83's Avatar
Re: slamming!!!
As I've been saying[img]/wwwthreads_images/icons/laugh.gif[/img], yes; I think it's your transmission. The adjustment doesn't even require you to open the tranny - it's done on the side of the transmission using a torque wrench (which you can probably borrow free from the Zone). You clean the area around the screw, pull the locknut (they recommend replacing it), set the screw at 10 ft-lb, and (on the C3 & C6 only) back it off exactly 1 1/2 turns (C4 intermediate 1 3/4, low/reverse 3; C5 int 4 1/4, l/r 3). Then replace the locknut at about 38 ft-lb. Even if I'm wrong, doing this won't hurt or cost anything.
Steve
Steve83 is offline
post #10 of (permalink) Old 02-07-2001, 01:32 PM
Re: slamming!!!
Cool, Thanks Steve, will keep you posted.
cmg
