-   Ford 67-96 F-Series, 78-96 Bronco (https://forums.off-road.com/ford-67-96-f-series-78-96-bronco/)
-   -   Aftermarket fuel injection (https://forums.off-road.com/ford-67-96-f-series-78-96-bronco/52730-aftermarket-fuel-injection.html)
Rockcrusher 01-13-2001 09:59 PM
Anyone know who makes an aftermarket MPI for a small block ford.
Rockcrusher
slickerthanyou 01-13-2001 10:15 PM
Re: Aftermarket fuel injection
I think i saw one at www.accel.com but not sure. what are you building
Backyard Builder
Rockcrusher 01-13-2001 11:18 PM
I picked up a basketcase CJ7 which included a completely rebuilt Ford 302. The engine has an Autolite 2V carb and I would like to replace it with MPI.
I know I can pull an MPI system off of a late model 302 with EEC-IV but that means heads, computer and wiring harness ... you know ... major mods. I was just trying to keep it simple.
By the way, the Accel unit is only made for Chevy engines.
Rockcrusher
Steve83 01-13-2001 11:52 PM
I pulled a beater 351 out of a truck and put in a 5.0L and I didn't notice anything about the heads that was specific to EFI - the injectors are in the manifold. I threw away the manifold, plenum, and throttle body when I changed it to the car style, because they were so cheap to buy in the junkyard. Check near you. It may be cheaper than you think.
Steve
slickerthanyou 01-14-2001 06:46 AM
I am taking out my 302 in my '90 bronco if you would like to buy the fuel injection, i'd be glad to sell it to ya. make me an offer! And anything else off the engine you would like.
Backyard Builder
**DONOTDELETE** 01-14-2001 02:18 PM
Sorry to be a little off topic, but, is there any difference between the FI on a 302 and 351? Could I use a manifold and injectors from a 302 to change my 351 to FI? Thanks
Sean Heberly
'85 Bronco 5.8L 4-V XLT: 266K still strong. Winter Truck now.
'86 Pontiac Fiero GT: 4.9L Caddy NorthStar Engine, 11.6 QM @ 107.1 MPH, Poly Susp, KONI's all around, 2 1/2" drop.
**DONOTDELETE** 01-14-2001 04:21 PM
The Upper plenum is the same but the 302 and 351 intakes are not interchangable because of the 351s increased deck height. So you'll have to find a 351 lower. Also if the setup is Speed Density, I would think that running a 351 with a 302 computer may not make the best running motor. Speed density will compensate - to a extent, I wouldn't know if it would matter to much.
'78 Custom 4"Lift 36"HummV tires Factory Rollbar-QuadShock-4Speed. '78XLT A/C, Cruise. '83Custom A/C and sweet paintjob.
Steve83 01-14-2001 05:52 PM
Some 302's use a smaller (different color) injector. Installing them on a 351 may cause them to burn out frequently because the EEC will hold them open longer, generating more heat in their coils.
Steve
