breather vents - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-08-2001, 04:53 AM Thread Starter
breather vents
Where are the breather vents on the diffs and trans. I seen a hose with a black cap on my rear diff and if you take the cap off it has a stem with 3 edges on it could this be it? If it's not what the hell is it? The reason I ask is because I use my truck for pulling a boat and a buddy of mine told me I should lenthen the breather vents on the rear diff at least cause water will get in there and f*#@ it up. Could anyone help this breathing situation or am I getting the wrong info. :-)
Backyard Builder
slickerthanyou is offline
post #2 of (permalink) Old 01-08-2001, 10:30 AM
Steve83's Avatar
Re: breather vents
It should be a soft black rubber hose on a nipple that is screwed into the axle tube on the driver's side of the diff housing, and the nipple also retains the brake line T-block. There is a hard black hose that is the brake line between the frame and axle, but it has crimped fittings and is screwed into the side of the T-block.
Steve
Steve83 is offline
post #3 of (permalink) Old 01-08-2001, 03:12 PM Thread Starter
Re: breather vents
Thanks again steve83 you the man!!!
Backyard Builder
post #4 of (permalink) Old 01-08-2001, 06:01 PM
Steve83's Avatar
Re: breather vents
No biggee, man. After you've completely rebuilt your truck, 3 others, and built 2 from scratch, you'll even know which kind of screws the factory used to hold the connectors on the back of the window switch. And you won't be married, either.
Steve
Steve83 is offline
post #5 of (permalink) Old 01-09-2001, 07:49 AM
Re: breather vents
My hero!
post #6 of (permalink) Old 01-09-2001, 07:36 PM
muddybronco's Avatar
Re: breather vents
If you're just pulling a boat you don't need to extend anything but the rear diff, and I doubt that's even neccessary. Mine had a line that went up to the body and was capped off stock, which should be plenty for putting in a boat. My tires barely get wet when I put in the bass boat, but I guess it varies depending on the trailer length. Of course, since my truck doubles as a dredge boat, all of mine have been run into the engine compartment, which would be a good idea if your truck sees mud holes.
It's a Jeep thing? My Bronco thing will run over your little Jeep thing.
Muddybronco
muddybronco is offline
