Drivers Door Light??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-06-2000, 11:37 AM
My inside dome light won't work for some reason when I open the drivers side door. When I open the passenger door it lights up like normal so I believe that the switch has gone bad. Does anyone have any expirence with this? How easy is it to get the switch out? Where is it located? Do I need to clean it or just get a whole new switch? Or is it even the switch at all? Thanks for the help....
Oh yea, I have a 1992 Bronco XLT
post #2 of (permalink) Old 12-06-2000, 12:41 PM
muddybronco's Avatar
Re: Drivers Door Light???
Yeah, it's the switch. Took me about 45 seconds to change mine. I think it's like 15 bucks at Ford. You just need a small 6pt socket set.
It's a Jeep thing? My Bronco thing will run over your little Jeep thing.
Muddybronco
muddybronco is offline
post #3 of (permalink) Old 12-06-2000, 12:50 PM
Thanks man, by the way could you tell me where it's located?
post #4 of (permalink) Old 12-06-2000, 01:57 PM
It's in the door jamb in the lower right corner, near where the seat belt attaches to the floor. It's black and has an accordian rubber boot on it.
Muddybronco
post #5 of (permalink) Old 12-06-2000, 11:57 PM
The door switch on my Bronco is located in the front of the door jam between the hinges. You can even get at it from behind by removing the side pannel under the dash.
Mine is an 86, and I've seen the same switch in the same location on a 97 F-250 (before the major body style change). Did Ford really move that switch to the rear of the door jam on later Broncos (and not the F-Series)?
post #6 of (permalink) Old 12-07-2000, 06:47 AM
I had ro replace mine on my 93 too. However, I also found that the wires in the plug were burned. Had to remove the plug and solder the wires to the switch. It also effects the map lights located by the dome light.
Nytom
post #7 of (permalink) Old 12-08-2000, 02:22 PM
Riff-raff, I'm not sure. On my 93 bronco, the driver's is to the rear at the bottom, but the passenger's is in the door hinges like yours. Kinda weird having two designs on one truck.
Muddybronco
