Re: 96 351w rebuild
In 96, vehicle emissions went to OBD I classification. You may want to check out the compatibility of your intended parts with OBD (if you even have it). You are doing a mild build-up, so it may not affect you. the work you are doing is pretty easy. If you are going with a new cam, get new lifters, and change the timing set as well. You'll have your chain and gears off to swap the cam anyway, you might as well spend the extra $50 for a new set. Get yourself a good manual, and follow the steps. make sure you torque everything down to the specs., and in the proper sequence. Repost any questions you have.
