is it smart to remove rear blocks? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-09-2010, 05:16 PM Thread Starter
Newbie
so i own a 1983 f-350, 351W, C6 trans, dana 50 ttb front and dana 60 in rear? what ever came stock..
what my question is i wanna lower the back of my truck and im wondering if i can remove the rear blocks and not mess up anything with the front suspension... as of right now my friend end kinda sits like this \ and im wondering if i lower the back 2" if that will make it to the point that it really messes up the alignment so that when i turn the tires point to the sky.. and what is the easyest way to fix this? helper springs?
'83f35ft is offline
post #2 of (permalink) Old 03-09-2010, 06:28 PM
stump runner's Avatar
so the front sits 2" lower than the back, and you want to remove the factory 2" blocks? I don't see why not, however, as with any suspension changes, you should get an alignment afterward. make sure you really torque those u-bolts, and recheck them after 20, 50& 100mi
stump runner is offline
post #3 of (permalink) Old 03-09-2010, 06:30 PM Thread Starter
Newbie
the only issue i can see with the alignment is the caster angle...and i dunno hwo to fix that on a 4 leaf suspension
'83f35ft is offline
post #4 of (permalink) Old 03-13-2010, 12:50 PM
there are tapered caster shims available if necessary, however I doubt you will need them. you are only leveling the truck out. Ford designed (in theory) your truck to work properly with a load in it. IE: level.
When you take it for an alignment, ask if they will be able to adjust to proper specs. if not, put caster shims in between springs and axle prior to adjustment.
post #5 of (permalink) Old 03-17-2010, 12:22 PM Thread Starter
Newbie
ok cool, thanks for the help
'83f35ft is offline
