Front and rear lift - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-03-2007, 04:16 PM
comebakthursday
Front and rear lift
I have a 95 Bronco and am looking to do a cheap custom 1-3 inch lift for the front and back(im looking for suspension and body lifts). I found a few but im kind of a newbie to this stuff and need a little more instruction then some of the stuff already on here. If anyone could contribute id appreciate it.
post #2 of (permalink) Old 09-10-2007, 02:24 PM
Quote:
Hey, I am going through the same thing right now! I have found that some lifts (usually the cheaper ones), are purely gear toward clearing a certain size tire. Others are for articulation. 4WD Parts has a database to match the lift to the size tires that you want to run. This helps a lot when you have already decided the look that you are after. Most lifts, for looks, will bolt right on, and can be done in your driveway, but watch out for drive shaft angles and steering peices getting out of alignment. Both of these conditions are associated with going too big on the lift, and are usually costly to correct.
ShortBus is offline
post #3 of (permalink) Old 04-02-2008, 11:37 PM
Brad33478
Bronco Lift Page
that site is pretty good on lift/tire clearance and different types of lifts.
post #4 of (permalink) Old 07-24-2009, 11:51 AM
u mite got lucky like i did i found on craigslist 4 300.00. i got it 4 200.00. it was on a bronco they were going 2 make it a mud truck and lost interest it was a 4" lift with extended radius arms. i found a set of wheels and tires 35.12.50 MT 4 450.00 got them 4 325.00. i did have 2 buy shacks.good luck.
bronco 1 is offline
