Re: Axle Swap
[ QUOTE ]
I need a new axle for my 93 F-150 4x4. The one that's in it had water in it and it whines like crazy. (I just bought it so no, I didn't do it.)
I have an axle from an 89 F-150 two wheel drive that I converted into a utility trailer. Axle is complete and in great shape. If the gears are the same, can I use the '89 axle? Both have ABS.
Dan
Might want to check that again. Like I said, both axles should be Ford 8.8s. Try checking both axle tags and see what you can come up with.
