Run away starter - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-26-2006, 08:16 PM
JWK
Run away starter
This one is odd
This with happen once and then nothing for 2 or 3 months.
91 full size bronco 302 5 speed
Turn key and start engine.
Engine starts.
Starter stays engaged.
Turn key off.
Starter still cranking
Pull batt cable off battery
rap solenoid
reconnect cable
Still engaged
Take batt cable off on a few more times
Stops
Fine for a few months
Solenoid has been replaced 2 times
What else could it be?
Is there another relay?
post #2 of (permalink) Old 02-26-2006, 09:03 PM
Re: Run away starter
I still vote for the soleniod. Let me guess, soleniods from Advance or some other auto parts store? We have been through probably twenty of those crappy things. Go to the dealership and get yourself a Motorcraft soleniod.
GTRider245 is offline
post #3 of (permalink) Old 02-26-2006, 09:42 PM
Look around for beefy looking suckers in the wrecking yard. [img]/ubbthreads/images/graemlins/smile.gif[/img] Well that's what I do!
BigNorm is offline
post #4 of (permalink) Old 03-27-2006, 12:56 PM
I agree go to NAPA or somewhere and get a Motorcraft, went through 3 in 4 months from Autozone before I did.
Mike in Magnolia is offline
post #5 of (permalink) Old 03-28-2006, 11:05 AM
Maybe your starter switch is malfunctioning. If it does this again disconnect the I wire from the relay and check and see if it's hot with a test light. If it's the starter switch then it should stop cranking when you disconnect that wire too.
BigNorm is offline
