EFI stroker - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-15-2005, 07:07 PM Thread Starter
EFI stroker
I recently purchased another bronco. This time it's a non-running 93 with a 351. The crank bearing's bad so I'm rebuilding it before I drop it back in. I'm wanting to stroke it out to a 408, but right now I'm on a budget. Do I need to get the MAF conversion to run a stroker? I'm also thinking about upgrading to an E303 cam. I know I won't see as big of gains without the MAF conversion, but will I at least be able to drive it until I can add the MAF on?? Also anything else that you think I might need to know, feel free to let me know what you've all experienced.
Rob
2facedbronco is offline
post #2 of (permalink) Old 11-16-2005, 01:06 PM
kemicalburns
Re: EFI stroker
you will either need MAF and a tune or a lightning ECU and a Tweecer tune for it to work. the E303 cam is not what you want to use either its meant for a mustang not your bronco.
call compCam for a recommendation. what heads were you going to use.? how about intake?
post #3 of (permalink) Old 11-17-2005, 10:37 PM Thread Starter
Re: EFI stroker
I've been wanting to get a Tweecer or something similar, as soon as I can get the $$ together. I've got a set of ported OE sbf heads (had them on a flow bench flowing slightly more than a GT40P head) SS valves, dual springs, titianium locks/retainers. I've got to run a stock intake for now. I may end up making a custom upper if I ever decide to add a turbo or 2 down the road. I've also got an AODominator (supposed to handle 750+ HP) in my 89 bronco that I'm going to end up using. I also have a 6" superlift with superrunner steering and 18" aluminum wheels that I'll be adding once I pay off the motor and buy some 35s or 36s. Anyone have any sugestions as far as tuners like the Tweecer. Also, if anyone needs any parts from my 89, let me know what you need.
Rob
[email protected]
post #4 of (permalink) Old 11-19-2005, 09:36 PM Thread Starter
Re: EFI stroker
I think I've decided to just get the MAF and Tweecer, but I have another question. If I'm swapping in the AOD out of my 89, am I going to have problems with my computer, by taking the trans out of the loop?
post #5 of (permalink) Old 11-24-2005, 08:08 PM
Re: EFI stroker
Is the AOD controlled electronically? Maybe AODE or E40D. The tweecer program will allow you to turn off tranny control or better yet adjust shift points.-Bob
slickerthanyou is offline
post #6 of (permalink) Old 11-26-2005, 03:29 PM Thread Starter
Re: EFI stroker
I just picked up a long block out of a 96 lightning yesterday that I'll be swapping into my truck. My AOD is not electronicaly controlled at all. Has anyone used a Tweecer or something similar? Anyone know where to find some ligntning guys I can ask for some advice?? Also, has anyone converted to MAF without buying the whole kit? I'd like to get the conversion done for less than the $600 for the kit, and I'm not affraid to do some work for it. ANY help or advice would be greatly appreciated.
post #7 of (permalink) Old 11-29-2005, 06:16 PM
Re: EFI stroker
[ QUOTE ]
Best place for this topic--- http://www.nloc.net/forum/
post #8 of (permalink) Old 12-22-2005, 12:00 PM
kemicalburns
Re: EFI stroker
check out www.fordfuelinjection.com. running the AOD is not that big of a deal. stroking will give you a bunch of power so you should pass on building an upper that is meant for hp not torque and turbos tht are for racing not 4wding.
