Re: Help!! 90 f150 4x4 not working
Apparently, somethings wrong with the right hub, your gonna have to remove it to inspect and be very carefull with those long taper allen head screws superwinch uses, they suck and the heads will strip out before coming loose if theres no antisieze on the threads. I have them and had to drill one out. They do offer a service kit with new screws and o-rings (which the o-rings most likely will rip when removed), for around $25. but i would suggest replacing with milemarker or warn premiums if budget allows. Dont get me wrong, their good hubs till they need service.
Hope this helps..
