Motor Swap ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-15-2005, 09:29 AM
davisa
Motor Swap ?
I want to put the FI 5.8 motor from my 88 Bronco into a 79 Bronco that is a race only vehicle. Will the 88 moter bolt right up to the auto tranny in the 79? The 79 is currently a 351 w/ auto the 88 is 5.8 w/ C-6 auto. Does anyone have any experience with swapping in a computer controlled motor that can give some advice on how to handle it. Will I need any special harness? How about the O2 sensors? This will be a race only truck. Any suggestions on what to do to the FI motor to get more power. Any help appreciated.
post #2 of (permalink) Old 06-15-2005, 04:41 PM
kemicalburns
Re: Motor Swap ?
well you will need to change trannies because the motor in your 79 is a 351m which uses a different bolt pattern then your 88 351w. also using the 88's speed density efi system would suck . I suggest you go maf kit from www.fordfuelinjection.com that would make going efi the easiest. you may also need to change the frame mounts as well. good luck
post #3 of (permalink) Old 06-15-2005, 05:10 PM
Re: Motor Swap ?
Yep.
BigNorm is offline
post #4 of (permalink) Old 06-16-2005, 01:43 AM
Re: Motor Swap ?
"because the motor in your 79 is a 351m "
Not 100% true... Could have came with a 302 and somone upgraded to a 351w [img]/ubbthreads/images/graemlins/smile.gif[/img] you can put anything in a 79 bronco!
Jacob_Royer is offline
post #5 of (permalink) Old 06-20-2005, 03:30 PM
kemicalburns
Re: Motor Swap ?
you can put anything into anything with enough money. put from the factory it wouldnt have the windsor family period
