stalling and hard down shifting - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-12-2005, 03:48 PM
Kuzmichj
I have a 1990 Bronco that I have been having trouble with for a while and have tried replacing almost everthing. It is getting worse now it seems but it's not setting any codes in the computer. most of the time when I come to a stop it will down shift hard and stall out. I am going to try the TPS its about the only thing left that I can think of . Has any one else had a problem like this. I have cleaned the throtle body , replace the IAC valve ,ignition moduel, coil , distributor pick up, MAP sensor, cap and rotor , spark plugs, checked for vacume leaks/intake leaks.
I am getting to my end of my rop trying different things and nothing working. Any help would be appriciated.
post #2 of (permalink) Old 06-13-2005, 02:31 AM
Re: stalling and hard down shifting
Will it stay running in nuetral ? if it will I think maybe your lock up torque conveter may be stuck in lock.
JWharden is offline
post #3 of (permalink) Old 06-15-2005, 04:45 PM
kemicalburns
your tranny must be the e4od? is the od button on the dash. if so you probably need to check/replace the mlpsolenoid this solenoid controls shifting and may also cause your issue. strange that your not setting any codes. you might also go to www.fordfuelinjection.com
