electrical
helppppp!!!!!!!!!!!!!!
i am running a 1988 broncoxlt w/a 1987 supercharger fuel injected 5.0..
my problem is i am not getting proper charging from my system.
i only show full charge at amp when i am turning 2000rpm.
i have had alt checked and even replaced alt. with what i have come up with with my little abality to do electrical it that on the big square plug from alt, which goes back to solinoid with a fuseable link the single wire from solinoid to fuseable link to the 3 wires is getting hot.. is this normal??????????
also the 3 wires coming from the small plug at alt. i get strong light w/test lite on the yellow/white stripe wire, a semi brite lite on the solid yellow wire, and a very dim lite on the green/red stripe wire....
again HELP!!!!!!!!!!!! [img]/ubbthreads/images/graemlins/confused.gif[/img]
