tailgate rust question, help - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-25-2005, 11:57 PM
kamiyama
I have a 94 Bronco..
The lower tailgate has rust spots on it..
Question,
How do I remove the window from the tailgate to get inside to fix this problem...
Or how else is this problem fixed...
Or what else can you tell me about this problem that would help me...?????????????????????
thanks
kamiyama
post #2 of (permalink) Old 04-27-2005, 12:52 PM
K5Blazerman77
Re: tailgate rust question, help
you shouldnt have to take out the window. dependting on how bad it is either cut it out or and weld in new stuff or sand it down get some rust neutralizer, and use body filler if you have to.
post #3 of (permalink) Old 04-27-2005, 06:29 PM
kamiyama
It's not really that bad that I feel I have to get to the inside.. but I felt this would be the way to go..
So pretty much.. work from the outside inward..
What seems to be the next question would be could paint to match what I have..
kamiyama
post #4 of (permalink) Old 04-28-2005, 08:24 PM
BRONCOMANIA's Avatar
Bronco lower tailgates are notorious for rotting out due to water dripping past the shelf on top due to deteriorated outer belt strips. You definitely should do a thorough inspection of the interior of the tailgate before painting cuz a few months later, you may be in for a real shocker...
work from the outside inward? Thats opposite of how the rust works.
All you need to do is open the tailgate, remove the access cover that has about 8 screws, push the striker bolt lock latches *in* on both sides of the tailgate as if the tailgate is in the closed position, then stick the key in the lock to extend the glass out so you can inspect internally. Some recommend you support the glass while doing so, however i have done this many times with no problems but if your concerned about the glass busting, by all means support it with whatever you can find the approximate height.
lower repair sheetmetal is avail from places such as jcwhitney.com, etc.
P.S. DONT forget to pull the latch to release the lock catches and roll the window back in before slamming the tailgate back shut [img]/ubbthreads/images/graemlins/thud.gif[/img]
BRONCOMANIA is offline
post #5 of (permalink) Old 05-02-2005, 04:53 AM
Drill drain holes in the bottom and hide the dammage with diamond plate. Well... That's what I" gonna do! [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/codger.gif[/img]
BigNorm is offline
