Vibration when I accelerate, what do you think???? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-23-2005, 07:21 PM Thread Starter
Hi guys,
I'm having some strange vibration when I accelerate, almost feels like a wheel out of balance, but it's only when I accelerate. I just greased my U-Joints on the driveshaft yesterday, and it started shortly after that. You think the grease got on one side more than another and is causing vibration? I dunno, but anyone have any ideas....I'm driving 2 hours each way tomorrow and wonder if it's wise with this going on.
Might help if you knew what I was driving huh......1993 F150 4X4
CJ7Attitude is offline
post #2 of (permalink) Old 04-23-2005, 10:21 PM
Re: Vibration when I accelerate, what do you think????
Out of balance?!, T-case or pinion bearing loose or worn-Happen to me-Bob
slickerthanyou is offline
post #3 of (permalink) Old 04-23-2005, 10:34 PM Thread Starter
Greeeat, sounds like fun. I have noticed there's some slop when I step on the gas, so that makes sense. BLAAAA, always something. Can't complain though, this thing has almost 200K on it.
post #4 of (permalink) Old 04-24-2005, 02:22 AM
Did you lubricate the slip yoke? It may not help but then again. it may.
BigNorm is offline
post #5 of (permalink) Old 04-28-2005, 12:06 PM
posar
Hi...
Had the exact same problem - My rear U-Joint was on the verge of crapping out - check for play in all of your U-joints. Is the vibration very noticable? Also, check for rear end bearing play...
Hope this helps...
post #6 of (permalink) Old 06-12-2005, 05:02 PM
Kuzmichj
You might want to check all of your u joints and if they are ok you may want to check you tires to see if they have shifted belts because that wil cause a vibration as well.
post #7 of (permalink) Old 09-16-2005, 10:02 PM
Bronco90
Try shifting into neutral and coasting if the vibration goes away or gets much better it is probably the U-joint.
I just replaced the ones in my '90 Bronco.
You might also check the balancing weights on the driveshaft, one of mine came off while I was replacing the u-joint and I had to tack weld it back.
If you can see where it came off you will have to get it balanced.
