-   Ford 67-96 F-Series, 78-96 Bronco (https://forums.off-road.com/ford-67-96-f-series-78-96-bronco/)
-   -   Bronc has the shakes (https://forums.off-road.com/ford-67-96-f-series-78-96-bronco/205959-bronc-has-shakes.html)
esm 03-10-2005 10:54 AM
Hi Guys,
My '96 302 Bronco has gotten the shakes lately. It seems to drive normal (considering its 299k miles) but when I stop at a light and it idles, it shakes like a big old diesel truck. The engine doesn't make any undue noises, just shaking like a wet dog. I don't even know where to start looking and I'm hoping some Bronco expert out there can give me a hint or two.
Thanks,
Ed
Lauge 03-10-2005 02:55 PM
Re: Bronc has the shakes
The easiest thing to do is check if all your spark plug wires are connected. You could be missing if which would be a lot more noticeable at idle. If that's not the case you might have some broken motor mounts.
L
esm 03-12-2005 01:51 PM
I forgot to mention that it doesn't shake in the morning when the engine is cold. Only when I drive it a couple of miles and stop at a light, I notice the shaking. That seems to eliminate both your possible reasons, right?
curtcon 03-19-2005 12:14 AM
after the truck warms up is it sometimes hard to start back up? If so check your timing. Is it a stock motor? I had a problem when I put my motor in my truck a stock 302 is internaly balanced but the 5.0 HO is externaly balanced and I put the stock fly wheel on the HO motor and it would only shake at certin RPM's. So I had to put the HO fly wheel back on the motor.
BigNorm 03-19-2005 06:54 PM
Have you checked your tranny fluid? I'm thinking maybe a torque converter problem? They'll shake if they're low on fluid.
Jacob_Royer 03-20-2005 11:46 PM
"1985 Cherokee "
Hey norm good luck with the cherokee! With a 2.8l you will need all the luck you can get!!!! I've had enough problems with those engines to go on for days about them.. I'd be looking into a 4.0 swap!
BigNorm 03-21-2005 09:40 AM
Hijacker! Well what's done is done. It's my new daily driver. Believe it or not it runs pretty good. I plan on running the motor till the wheels fall off then maybe I'll throw a 302 in it. lol
esm 03-21-2005 03:10 PM
Yeah, it's a stock motor. It drives great, so it doesn't seem to be the timing. The tranny fluid is checked every month when I get an oil change. What else could it be?
curtcon 03-21-2005 09:45 PM
Is the idle low or is it idleing ok? Maybe motor mounts.
esm 03-23-2005 01:27 PM
The idle is okay, there's no difference between cold or hot idle. Wouldn't the motor mounts make excessive noise?
BTW, why are the Cherokee posts in my thread?
