- Ford 67-96 F-Series, 78-96 Bronco
(https://forums.off-road.com/ford-67-96-f-series-78-96-bronco/)
- - 85 Bronco
(https://forums.off-road.com/ford-67-96-f-series-78-96-bronco/204186-85-bronco.html)
85 Bronco
I have purchased a 85 model Bronco. I need to know if this yr model has two fuel pumps and where of the pump(s) located?
Thank you for your help. [img]images/graemlins/thumbsup.gif[/img]Any member on here from GA and or surround areas in Atlanta. [img]images/graemlins/40BEER.gif[/img] |
Re: 85 Bronco
I don't know a lot about brancos but if there is two fuel pumps one would be in the tank and the other would be on the fram rail under the drivers seat.
Re: 85 Bronco
I'm from Lawrenceville/Gwinnett area. Where you from?
Re: 85 Bronco
Carb'd? some 85's had injected 302's, if it is fuel injected then yes, if it's carb'd then no...
Re: 85 Bronco
Curt's right
There's two and that's where they are. It shares almost everything with an 86, then quite a bit of changes occured after that. The front pump is under your brake foot on the frame rail, the funny shapped fuel filter canister is under your seat and needs this filter; http://www.superford.org/getfile/141...e/IMG_0114.JPG Sixlitre |
Re: 85 Bronco
THANKS A LOT FELLAS AND GT IM IN POWDER SPRINGS/COBB AREA.
User Alert System provided by
Advanced User Tagging (Pro) -
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBSecurity v2.2.2 (Pro) -
