transmission temperature gauge - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-04-2005, 11:44 PM
So I installed a tranny temp guage a while back and decided to put the sending unit (temp reader) in the pan. It seemed like an ok idea at the time but I know realize it is a fairly innacurate reading and want to change it. I realize the ideal place for it would be in line with the output line from the pump (the one going to the cooler) I have an auxilary cooler with rubber hoses going into it. So my question is does anyone know of a tempterature sending unit I can screw into either the metal line from the tranny, or splice into the middle of the rubber line? Or if anyone has done it any other ways that input would help too. I have looked all over the internet for this type of piece I can splice in to the line and have come up with nothing. Thanks for any input. Its a 90 Bronco with a E40D by the way.
post #2 of (permalink) Old 01-05-2005, 12:59 PM
Re: transmission temperature gauge
Here's the $20 solution to your dilema;
Plus you'll get a remote filter for your super expensive transmission out of the deal.
The part;
Summit list this remote filter housing under Perma-Cool number 5021 and at $20 it's a lot cheaper than any kit available. I bought it to replace my Fram one because I want to hook up a trans temp gauge.
Read about the rest of the install here;
http://www.superford.org/registry/ve...=17326#content
Sixlitre
Sixlitre is offline
post #3 of (permalink) Old 01-06-2005, 01:47 PM
I have been considering that as an option, and I suppose it cant hurt to have a remote filter, where did you get the gold input and output fittings and what do you call those? Thanks for the input. Also do you know which line on this transmission is the output and which is the input? Thanks again. [img]images/graemlins/scs.gif[/img]
post #4 of (permalink) Old 01-06-2005, 05:15 PM
A dollar a piece at Princess auto
and they're called barbed nipples. Summit's $34.00 house kit includes them and some hose and clamps (I had all that).
On my AOD the line out of the trans furthest forward is the out line and the one farthest rearward is the in line.
Not only can it not hurt, it can help tranny life unbelieveably !
Sixlitre
Sixlitre is offline
post #5 of (permalink) Old 01-09-2005, 01:46 AM
I thought about what I wanted to do with this and I ended up putting together something for about 15 bucks. It works beautifully and is very responsive to changes. Do you know if the tranny lines (send and return) are the same for the E40D??? I have it hooked up to the one I think is the send, which would be the hottest fluid, but Im not sure...Thanks again
post #6 of (permalink) Old 01-10-2005, 05:34 PM
I have one that is mounted in the pan it gives me a great reading and i have not had any problems. I also have a $100 200psi gauge for my trany pressure so i can tell exactly what is going on and again no problems there.
snowmancat is offline
